Hi guys,
any recomendations for a good cut n polish place? Care to post up prices and locations if possible please.
Didn't want to do it myself, want something more 'professional'
Thanks!
i'll send u a pm i can prob help u out :P
https://www.sau.com.au/forums/topic/166918-cut-and-polish/#findComment-3088622
Hi guys,
Thanks!
MAV is the man..(2nd free plug for the day)
https://www.sau.com.au/forums/topic/166918-cut-and-polish/#findComment-3088698
I know someone that does them from his backyard has all the tools, washes, cuts and polsihes and paint protects. etc..he is actually a detailer at oakleigh nissan whatever its called now. Everything he does is top work he just did my mates r33.
He charges 100 for the cut and polish or 150 for cut and polish and paint protect.
he's in bayswater..but hey mav is probably betetr to got rhough since he seems to be organising some good stuff.
https://www.sau.com.au/forums/topic/166918-cut-and-polish/#findComment-3089801
I cant find an address for these guys?
Would you happen to know it? Got a problem only a real professional car detailer may fix :)
Just use the booking form on that site they'll get in touch with you.
They don't have an address yet, have a place opening soon though.
https://www.sau.com.au/forums/topic/166918-cut-and-polish/#findComment-3090758
Would you happen to know it? Got a problem only a real professional car detailer may fix :D
You can't get more professional and REAL than Final Inspection.
They do on-site detailing. Meaning if you can provide water and electricity, they can go down.
Book early though, it's more or less fully booked all the way till mid-June ATM.
https://www.sau.com.au/forums/topic/166918-cut-and-polish/#findComment-3091397
Sounds Like your the Man Mav, What can u recommend me I have a white car, and lately its been looking like a dirty two dollar whore, only coz i neglect cleaning it. I want to give it a thorough cleaning this weekend. Also ive been using some Amourall? Rim cleaner that leaves feral white residue all over the rims like some deviot has shot his load all over them. whats a good rim cleaner?
cheers
https://www.sau.com.au/forums/topic/166918-cut-and-polish/#findComment-3093112
cheers
I personally don't use products like that on my rims i prefer to use a wax or something not so harsh, also something that will in turn protect gives a much better result if you go down that path...
If its looking like a 2 dollar whore im sure we can work something out to get it not looking like a whore again :P
https://www.sau.com.au/forums/topic/166918-cut-and-polish/#findComment-3093225
cheers
A white car should be the easiest to look clean. A proper cut and polish and wax will make it so easy to clean, dirt just wash off.
As for rims, use Power Wheel Cleaner (PWC). Cleans rims real quick and easy and is safe for the finish. Then, use wheelwax to protect and shine it, so it's easier to clean them in the future. Wheelwax also has some cleaner in it. After using wheelwax, I only use high pressure spray to clean the rims. It lasts for about 1-3 months.
http://www.wheelwax.com/
https://www.sau.com.au/forums/topic/166918-cut-and-polish/#findComment-3095550
4th, 5th, 6th, 100th F.I. (final inspection) - Damian is the pro of pro's. You would struggle mightily to find a better detailer in the ENITRE country.
Megs make some good products, but don't quite cut it next to some of the top products. Can get all the best stuff from final inspection as well.
All depends on how fussy you are. If you're not too fussed, you could probably just raid autobarn for Meguiars products.
Or, if you're really keen on your paint/car, you'll find the next level of stuff through final inspection. And it's not that price inhibitive, and less is more when using some of the best products.
2nd PWC (power wheel cleaner), and the F.I. MSTD (mid-sheen tyre dressing, not that super wet chapel st look). And yes, wheel wax afterwards, to help prevent brake dust build up, and basically just let you high pressure water the rims clean with a bit of PWC at your next wash.
If someone is cutting and polishing, you can't just leave it after the polish. You must apply some sort of wax/sealant afterwards to protect the paint/clear from all the crap in the air/bird droppings, etc.. this LSP (last stage product) will also help A LOT in the depth and clarity of the paint after the polish.
A great, easy to use wax, OCW - Optimum Car Wax - a little carnauba, and part synthetic. Dead-set easy to use. Make sure you have some TOP quality MF (micro-fibre) cloths, otherwise you'll just put swilrs in the clear when buffing the wax.
all in the preparation...
https://www.sau.com.au/forums/topic/166918-cut-and-polish/#findComment-3096185
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
