hey mate im after the loom which goes from ecu to the engine do u still have it and if so how much u want for it?
Sorry mate, that went to the scrap metal yard with the car. Didn't have the patience to pull it out for the money its worth. Sorry buddy.
  • Replies 85
Bump up she goes....
Turbo sold
Splitfires sold
Handbrake sold
Anyone interested in the block or head, make an offer, its taking up way too much space I want it gone. Throw me a figure I may just take it.
Diff is still here as well people.... Will sell for $300
the pair of 1/4 panel indicators including both male and female plugs?... how much mate?
Sorry mate I just have the indicators, not sure about two different plugs?
$100 for them both.
Hey mate,
I'm after the passengers side bracket for the Din slot.
Do you have this?
The part I need runs from the top left circle to the bottmo left arrow. I already have the one on the right.
If so how much? and
Whereabouts are you? Willing to come and collect it as soon as possible..
Hey mate,
Do you have this?
If so how much? and
Will sell them as a pair, I won't be able to sell just one. So pricing $30 for the two.
Located in Bangor, in the Sutherland Shire. (30 mins south of the CBD)
Bump, up she goes.
Drivers side door sold.
Turbo sold
Turbo back exhaust sold
All 4 hubs and calipers sold
Gearbox sold
Still got heaps left people, including the diff! Make an offer on anything, I'll probably take it, I want it all gone now, any reasonable offers won't be refused.
Anything not sold within the next few weeks will be taken to a wreckers and whatever offer I get from them will be taken.
  • 3 weeks later...
do u still have the front n rear discs n calipers ? how much to peakhurst ?
No I don't sorry.
OK everyone, all the parts are definitely going to the wreckers this weekend if I do not sell them. So here are some new prices
Front seats: $150 for the pair
Intercooler: $150
Diff: $175
Suspension: $100 for the lot
Dashboard: $100 for the lot (Console, facia, gearstick surround, glovebox)
Rear Seat: $50
Front bar: $40
FR Quarter Panel: $75 (including indicator)
Climate Controls: $40
FR Headlight: $75
Rear interior trimmings: $40 for the lot
Door Sills: $20 for both
Bonnet (Has large dent, but repairable by any panel beater): $40
Fuel tank: $30
Engine Head: $300!
Block (Needs two new rods, and honing on two cylinders, suit someone looking to build from scratch): $300
I have plenty of other stuff just laying around, but can't think of it right now. Make an offer on anything I'll probably take it.
Edited by ProphetR33
Ok everyone its now getting torn apart.
Everything is up for grabs except for my confirmed sales of
The Gearbox, tailshaft, Turbo back exhaust and FMIC.
Engine including loom $2000
ECU $100
Diff $350
Radiator $150
Throttle body $150
Standard turbo $330
Standard cat (2 months old) $75
Air box $75
Snorkel $50
Dry cell battery (vented) with good charge $30
Anything from undercarriage is salvagable, likewise with engine bay.
Exterior
Drivers door: $150 (Mirror damaged, otherwise good condition).
Rear left tail light assembly: $100
FR quarter panel (including blinker) $125
FR headlight $175
16" Alloy R33 Wheels $350
16" Space saver $150
Rear quarter windows, $30 each
Interior
Drivers seat $175
Passenger seat $175
Rear seat $200
All seats $400
Instrument cluster (48,000km on clock) $100.
Dashboard outer assembly (width of car, including glovebox) $250
Inner surround top (stereo, instruments, air con) $50
Gear stick surround $40
Center console (from rear glove box to front dash) $150.
Auto gauge, guages boost, AF ratio, volt $35 each, $100 for the lot.
Need any other parts? Just ask everything is available
Hey mate. im after the part of the dash that surrounds the stereo etc.Is it in good con?
Im in Sydney.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
