  • Replies 116
Under hard driving on the street you feel a bit more confident but in reality you are traction limited long before the brakes run into problems even with a quality standard sized setup, so it's not really possible to experience anything extra the G4 kit might give you.
I think it worth emphasizing this point, the tyres are the limiting factor in braking performance in most Skylines, not the brakes themselves. If maintained properly, the standard 4 spot front and 2 spot rear brakes are more than capable of outbraking the best/biggest road tyres you can buy.
:kiss: cheers :D
  • 11 months later...
As far as multipiston theory goes... I always thought it was to give greater leverage on the rotor for the same diameter of rotor. In a racing series brake diameter is limited by wheel size or regulation. You can run bigger rotors by running low profile calipers but also the further out you put the pad the more leverage it has.
Anyway just a theory I made up, so feel free to ignore it. I drew something in MS-paint using the pad on my laptop but then gave up cause it was too hard. Anyway just based on Torque = Force x Length it made sense to me.
Thats partly it. The other is a longer pad means more surface area of pad which helps with lower pad temperatures meaning less need for craxy high temp pads. Also the fact that the narrower pad means for a given rotor diam you have a shallower pad which allows you to run a narrower steel rotor with larger alloy hat reducing unspring weight. Also the larger pads means you have less localised heating of the rotor which at high temps can help with the onset of rotor warping. Then you have the more even pad wear...there are a whole bunch of reasons. If i wasnt drunk i could think up some more :wave:
I had the opportunity to look at a set of these last week and I was surprised at how small the mounting hardware is. Grossly undersized in my opinion, flex just waiting to happen. Bolts coming loose is a telling symptom of that problem.
Cheers
Gary
Does anyone have the measurements of these calipers, or a spec sheet?
The design is a knock off of an AP from memory, if I can't get the measurements, does anyone know which caliper they copied?
Cheers
Dane
ok well if u guys have only ever heard of these g4 brake calipers coming loose ive seen worse.
r33 gtst here where i live fraser coast has a set of alcon 8 pots front and 6 pot rears. it was driving along behind him and the right rear suddenly locked up solid flat spotting the good ol nankang lol. now like i said alcon like 8 grand of brake front and back and one of the bolts thats hold the caliper to the original bracket had come out and the whole caliper flicked up hitting his 19inch chrome wheels. i couldnt help but laugh at the time cuz all he did was take the caliper off put a set of vice grips on the line and drive it home. either way moral of the story never blame the equipment until proven guilty. and yes loctite always comes in handy.....
now im not saying u didnt do a good job at tightening ur bolts either ok so dont have a go lol.
Cheers
Dane
I've got a pair of Monobloc 8-piston Brembo's & before they went on the car I put them on the bench side-by-side with a pair of the D2's. From memory they were pretty much identical as per the piston spacings & overall dimensions etc although the pics of the G4's at the start of this thread appear to have a large leading piston & 3 small trailing pistons whereas my Brembo's are staggered big-small big-small.
The other big difference apart from the monobloc construction vs the 2-piece construction of the D2/G4's was where the D2's use on single pad per side, my Brembo's use 2 pads per side with the ability to "quick change" the pads out thru the top so they are effectively 2 sets of 4-piston calipers sharing a common body & hydraulic circuit.
They def seem to be a "knock-off" but whether they copied Brembo directly with regard to the piston specs or copied the AP's which in turn copied the Brembo's (but went to a single pad to avoid patent-infringement etc), I don't know.
...whereas my Brembo's are staggered big-small big-small.
... my Brembo's use 2 pads per side with the ability to "quick change" the pads out thru the top so they are effectively 2 sets of 4-piston calipers sharing a common body & hydraulic circuit.
Thats why your caliper does the big small, big smal differential piston sizes, because as you noted you effectively have two 4 piston calipers in one with you running the two pads. If the caliper only used 2 pads, one each side you would expect the traditional small leading and larger trailing pistons
I upgraded to these from the 33/34 brembos. the brembos are rubbish for such a heavy car with so much go. the g4s are 21mm bigger slotted discs, calipers are bigger and lighter, and the pads are about 20% bigger too. No comparison
Great write up, thanks for taking the time!
Guys are the stock GTR brembo's really that bad?? Most people say the stock 33GTSt calipers are much underestimated, and the GTR brembos have got to be a yard ahead of those surely?
Im planning a top end brake upgrade for my GTR and conveniently upgrade my GTS-t with the old brembos front and rear at the same time.
The OE GTR Brembos are pretty good calipers. Problem is when people ask the money they do for them. Its the whole supply and demand thing. There are some other attractive options when you are looking to pay $1600 odd for front calipers with used rotors and pads.
And as far as OE Brembos the Nissan caliper is behind most others fitted to EVOs, STIs, Jags etc
the G4 can take a AP 6pot pad as i got some from from a guy in the BTCC.
As far as i can tell they are a thing of beauty for the money got 2000 kms out of the last set of rotors and its a track only car. I was more than please as they lasted the same amount of kms as my mates RBA 5000 on my mates EVO track car
  • 2 months later...
I just wanted to post somewhere in here that I have now had the opportunity to use the "race" pads that Just Jap sell for the G4's. I have standard rear brakes with BEndix Ultimates in there and find that not only is there no bias issues, I have fixed a bias issue that I believe the car has from factory. I was regularly cooking rear rotors and pads before but now it all runs fine. Lap times are down and the car stops amazingly. I was regularly braking far too early due to being used to the standard setup. With the addition of good tyres and these brakes I knocked 3 seconds off my previous pb at Wakie.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
