Just wondering if anyone knows where I can get a Catch Can locally, I need it asap so dont want to buy it interestate.
Cheers
Ric
car toys, customshine, boostworx? or you could go the alternative route... your choice really =)
forza recomends mount franklins after his bad experiance with schweps :rofl:
Edited by Fishpaste~
https://www.sau.com.au/forums/topic/167261-catch-can/#findComment-3094649
Thanks guys, I spoke to Shaun and he mentioned that ASE or whatever they are called, but he said they charge around 200-250 for a catch can, so not prepared to spend that much money on one. :thumbsup:
I was thinking more like 100 bucks, D1Spec cheap brand or something.
Or I might go Evian, always like to get the good quality stuff for my car :rofl:
https://www.sau.com.au/forums/topic/167261-catch-can/#findComment-3094804
forza recomends mount franklins after his bad experiance with schweps :thumbsup:
Hi5!!!
LOL@FORZA!!!
I would say Just Jap but thats interstate :rofl:
Doesn't Auto Barn sell them?
https://www.sau.com.au/forums/topic/167261-catch-can/#findComment-3094954
OH shit, too late there with the offers guys!
went to Autosport or whatever you its called on Magill, and bought one for $110 bucks looks pretty good 1litre capacity, but its just the can no kit :pwned:
u serious? y would you buy only half of something?
https://www.sau.com.au/forums/topic/167261-catch-can/#findComment-3100106
I figured some rubber hoses and clamps cant be that expensive to get anyway, and the quality of the thing is much better than the ones ive seen going around in kits anyway. so yeah.
Any hoses and clamps laying around? :blink:
I have some used braided hoses, new blue silicone, new black rubber hose & the cheap clear hoses laying around. :action-smiley-069:
Did the catch can come with a baffle?
https://www.sau.com.au/forums/topic/167261-catch-can/#findComment-3105424
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
