I have for sale the brakes off my R32 GTSt.
For sale are the following items:
Calipers
Front 4 piston (alloy) that are in great condition, were rebuilt and HPC coated, incuding pistons to reduce heat transfer into fluid.
Rear 2 piston calipers (alloy) that were rebuilt, though not as recently as the fronts. Were painted black but paint all but worn off. Paint was nowhere near as durable as HPC coating
Pads
Fronts - Ferodo DS2500s. Have done three track days (approx 25 laps total) and less then 2,000kms of street driving (new price $296.00)
Rears - Race Brakes Comp 2s. Have done 4 track days and approx 5,000kms. (New price $220.00)
Both sets of pads still have plenty of meat on them.
Rotors
Front - Near new 324x30mm DBA 4000 slotted rotors. Are normally replacement rotors off R33/34 GTRs. Have done 3 track days and less then 2,000kms of street driving (New price $450.00)
Rear - Near new 297x18mm RDA slotted rotors. Have done 3 track days and less then 2,000kms of street driving (New price $255.00)
Adaptors
Adaptors to allow you to run the 324mm front rotor with std R32 GTSt calipers. Machined from billet alloy. Have used these brackets extensivley on the track and there is no issue with regards to their durability. (Replacement cost for brackets is $800 less rotors, so around $350.00)
Asking $1100 ono for the pads, rotors, adaptors and calipers. Will include front and rear braided lines for another $100. Far cheaper and in better condition then 2nd hand GTR brake setups with essentially the same ability to handle thermal loads and essentially the same braking force (Pistons in calipers have slightly less surface area)
Will consider splitting gear, but really would rather sell as a kit for a guy wanting good brakes for the track. If you dont want all if it then maybe you can flog off what you dont need.
Front rotors - $350
Rear Rotors - $150
Front Calipers, pads and Adaptors - $600
Rear Calipers & pads - $250
Front & Rear braided lines - $170
More pics will be available after the weekend.
https://www.sau.com.au/forums/topic/167397-324mm-brake-upgrade-for-r32-gtst/
  • 2 months later...
Price is negotiable and will throw in braided lines to boot. Its a good budget upgrade for a GTSt, much cheaper then a GTR Brembo setup with what you can bet on beign rotors and calipers in far batter condition then you woudl expect buying used GTR Brembos
Bugger. Was hoping these had sold by now. Previous buyer pulled out after buying R33 brakes.
Willing to sell rotors and brackets so you can use your own caliper. Happy to sell calipers by themselves. They are sitting around doing nothing so best someone get use out of them
  • 1 month later...
i put the brakes back on the car as i didnt want to trial the new setup at a rally i was entered in. Problen is i cracked a rotor...good thing is i replaced them with brand new DBA4000 324mm rotors. So the kit now has rotors that have done some motorkhana work and a few laps of Winton and Sandown and less then 500kms.
Had a fair bit of interest but no firm committment. Will let the rotors go for the same price if they are bought as part of the front kit.
Any idea if this will fit on a 200ZR???? Cause I need new brakes but farked of I know what will fit! lol
I'd be looking at the whole setup if it does :closedeyes:
i got a 6/93 GTR R32... interested in front rotors... fit? im assuming so lol but always better to ask..
best price u can do? and location
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
