Hi All,
I am hoping everyone had a grand old time last nite, I know I sure did even though I had to work. I hope that the pizza was adequate and delicious.
Tell me what u guy's think if we meet up for pizza and a cruiz every 2 months or so??? Just an idea for something regular for us to catch up.
Take care guy's untill next time!
Mark
:P
https://www.sau.com.au/forums/topic/16743-last-nites-cruiz/
Pizza was Yummmo.. :P Thanx Mark!!
Nice to have met you guys..
Milk...... you crack me up girl.. :)
And Pred.. you remind me of the guy in F&Furious big time.. lol
Cant wait for Sunday now... still scaredddddddd.. lol
TTFN
Kyles
https://www.sau.com.au/forums/topic/16743-last-nites-cruiz/#findComment-346850
lol ..
Ask any racer, any real racer. It doesn't matter if you win by an inch or a mile; winning's winning.
hehe
nice car too kyles.. luv the rims! i should have mine back tonight.. and u know what they say about red (well burgandy) cars.. we should have the others covered ezy :P
yup, sunday should be good, hopefully everybody comes who said they would - its an early start! but should be worth every minute of it.
https://www.sau.com.au/forums/topic/16743-last-nites-cruiz/#findComment-346932
thats great guy's I also had a great time. I can't wait untill we do this again!!! Maybe we can go somewhere else for food so it can be fair for those who traveled for ages to come down. I love ur car BigPsi!!!!!
32 ENVY there will be many other times for you to come, next time no excuse ehh!!!
:P
take it easy guy's
https://www.sau.com.au/forums/topic/16743-last-nites-cruiz/#findComment-347260
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
