***SOLD***
Dont really want to sell them, but with a change in the domestic situation need to move the bulky gear laying around the apartment.
Selling because i only need a single set of rims, so going to keep my track rims which are the same width meaning i can rotate tyres. The LMs were to be my street rim , though i never got around to fitting them.
Wheels Sizes
Front - 17 x 8.5 +40 offset
Rear - 17 x 9.5 + 36 offset
Im still to apply the Nismo stickers.
They re fresh from being professionaly powdwer coated in the exact colour i wanted for the car. Asking $2,000 ono for rims only. Truth be told im asking what i am because im hoping they dont sell :blink:
https://www.sau.com.au/forums/topic/167465-sold17-nismo-lm-gt4-rimssold/
These rims are awesome and are super light-weight.
They have been powder coated by the same person that has done my 19" rims. My powder coat has lasted 3yrs (so far), including track days where wheels get pretty hot, without fade, bubbling or cracking.
All the best Bris!
Damn, i wish i had that sort of money! Those wheels are awesome - It would be a dream if i had them fitted on my car.
All the best Bris!
I believe that same person also powdercoated my standard wheels. He done an awesome job.
All the best with the sale, too bad you have to let them go. Whoever purchased them will be mega lucky.
Cheers,
Steve.
  • 3 months later...
Silly me purchased another set of rims...so i now have a set on my car, a set in my bedroom and the LMs in the lounge room. So if you are serious then touch base with me...depending on my mood on the day my price could be flexible
how would those offsets go on a 33 gts-t
my mate has 18x8 +35 on the front and 18x9 +35 on the rear...his rears look mad so these rears would probably sit the same, but his fronts would look better if they sat out maybe 5mm more so would these sit in even further?
Ok, some quick thinking. The fronts are 12.7mm wider with 5mm more offset. So the result will be that these will sit in about 2mm closer to the shock and sit about 12mm further out. So sonce these will sit out about 12mm more, then thats 7mm mroe then what you are thinking.
Hope that helps.
nope...just confused me... I thought +40 sat inside more than +35..and +30 meant they'd further outwards....?
Yep, +40 sits further in. But you said your friends were 8" wide fronts. Mine are 8.5" so are half an inch wider. So they in turn will sit out more then your friends, with only a smidgen less clearance on the inside
damn 17" wheels are ultra hard to sell these days - if they were 18s they would be gone in a flash. If you get desperate to sell, fire me a PM Roy - unfortunately for you I have recently bought some gold WORK Gram Lights for my R34 - if I hadn't bought these I would buy yours in a flash. Other problem is that I have a set of ROH Blades, a set of Enkei Circlars, a set of R33 stockies, and a set of R32 stockies sitting around too - the wife might divorce me if I buy another set. However if they were the right price I wouldn't be able to resist.
ah damn..prolly sit out too far on a 33 gts-t then :thumbsup:
ah damn..prolly sit out too far on a 33 gts-t then :)
If they fit an R32 GTSt then they woudl be ok on an R33 which swallows most rims that struggle to fit on an R32 GTSt.
Yeh, 17" wheels arent really the flavour of the month anymore. But i dont want bigger, just more weight and expense. For me a nice light 17" wheel with nice good rubber on it, reasonably wide as they are 8.5" and 9.5" wide is the go. they no longer suit my needs as i really need to be able to rotate my track tyres front to rear which means 8.5" wheels all round :D
I have to pop up to Sydney to do a few thngs. So if anyone wants free delivery and will pay the 2k then they can deliver them for free to metro Syd on Wed afternoon. Only Wed though
Can I have them please? I have sent you a PM.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
