Hey everyone... recently i've had my gearbox oil and diff oil changed, i noticed under the car when the mechanic was probably draining it they spilt a little on there. Pretty much after i've had this done i take my car for a bit of a "spirited drive" and i notice this weird smell coming from around there, it sort of smells like gearbox oil burning or more of what i can smell "burning shit"
I was wondering if its just the little bit of oil thats still stuck on the box that could still be giving me that smell or if its something more dramatic... also i don't know what detonation smells like wether its a werid stench and wether i should be worrying about it, the mechanic is a bit busy and i thaught if anyone on here could help it'll help me out heaps..
Thanks in advance :teehee:
https://www.sau.com.au/forums/topic/167742-weird-smell-from-car/
hmm i wonder what it might be... what does detonation smell like? i dont get no warning light and i don't have a knock sensor (pfc not in as yet).... is there a certain sort of smell that i should look out for?
stupid questions but hey i'm a nOOb .. and i've used the search function
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
