Hi All,
Just aquired a cushion button clutch for my GTS-T, before I go ahead with the fitment I wish to find out more info about what short shifter is best recommended and most commonly trusted by fellow club members. Where can I obtain one?
Ebay has them going for $60-$120AUD for Billet Aluminium ones.
Thanks Guys & Gals.
Edited by MissRB25DET
Hey tash.. I don't know if button clutch would be your best choice, a sprung center gives a lil more flex slightly easier to drive and not as aggressive..
With short shifter i think thats a personal choice i got a NISMO(i think) one off ash and i think its ace although i don't think he liked it.
Thanx for the advice guys.
You wouldn't by any chance know the tension (Nm) for the flywheel bolts.
I was told the Exedy Cushion Button will allow for everyday driving yet handle track use extremely well too.
i got cushion button they are tops. great for everyday driving
+1 for C's. May take a while to get used to it tho as the throw is about as short as you can go.
You may find that you need increased effort to shift as it gets tighter because of the leverage point or something about how it works.
I love it but its personal preference i guess.
I've got the Tomei short shifter, really good, short throes, but the nylon bush/sleeve on the very bottom of the shifter is worn, and loose - need a replacement. Does anyone know if there's a Tomei service kit available? It just adds an unnecessary amount of slop to the shift.
ash, why didn't you like the short shifter?
dan, they will only be worse on the box if you bang it in all the time...
I had one on my BMW and it, along with the Momo Corse, were the best mods ever (that includes a built motor for it!)
It makes finding gears harder was the main thing for me
When i was racing a lot at Calder/Heathcote i found i was shifting faster without it.
Also i was missing gears far less as when there is a short throw, you have to be precise everytime.
I also was out-shifting the box sometimes i think, as it would crunch horribly. Shifter removed, never a crunch.
And it wasnt my useage of the clutch :)
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
