It has to do with the weight of Stageas ~1700kgs, the fact that they share the aerodynamics with a tissue box, and how you use your throttle, and the fact that you have 4wd too.
I had my power-fc tunes for economy and was reeeeealy gentle on the throttle and got 9lts/100kms out of her.
Read this thread:
http://www.skylinesaustralia.com/forums/in...945&hl=fuel
holy crap joe! mine would be lucky to get 300 :blink:
you serious on you car you only get 300km/tank? Im getting 400-450/tank. you better go for a retune buddy it will save you in the long run. if thats the case use boost 98 to cut costs man.
Average 11.7L/100km in town, 9-10L/100km on the highway.
It all comes down to a good tune, and a controlled right foot...
oh, and adelaide traffic isn't as bad as in other states so your results may vary a bit...
but then with better roads like in QLD I averaged <11L/100km when on holiday in brisbane...
300km would be correct, with no safc and with a shagged exhaust temp sensor....
I was on around 320-350kms then replaced the exhaust temp sensor and added an safc and it got 450km (fuel light staying on) with 140awkw.
after a retune soon to suit the different muffler, incl adding on an adj cam gear wheel, should get 190awkw and still be around the 400km per tank mark.
i get 200 KM to the tank in city
around 300 on the highway
man is your foot made out of lead or wat?your car got a serious problem. I think it definetely can guzzle gas quicker than all of us guzzling a pot of cold beer!!!! :rant:
i also changed o2 sensor, and it improved slightly....
but as i said im getting an safc in the next couple of weeks, and i will also try and track down an SITC
who sells this boost98?
united. search for the thread on boost 98. and there a link in there which will tell you where boost 98 is available. its good stuff.
Say you call "a tank" 50lt to be conservative as 200km is ridiculous anyway you swing it... That's 25lt/100km
What modifications have you got mechanically to achieve such a stupid result? Larger injectors and unburnt fuel running out the exhaust?
I suggest you check the "gas" tank for holes there boy! I'm sure driving "style" is a contributing factor...
lead footed? or the engine is a real "gas guzzler" like the yankees like to say.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
