High flowing the stock turbo
Guest MFX_R33
How much extra power would u get from High flowing it... Just curious.. Will it reduce the reliabilty of the turbo.
I have got 205kw @wheels with this turbo at 17psi (this is pushing the efficiency limit of this turbo). The standard turbo has ceramic wheels, which have a tendency to de-laminate at around 14psi causing the turbine wheel to end up in your exhaust.
As far as it spooling up slower, I havn't noticed any difference. It spools very easily with almost no lag (as with the standard).
Jeff.
Originally posted by MYGTST
the standard unit is made by hitachi
garett quoted me minimum of $1000
benifits are you can run more than 14psi reliably
downside may take longer to spool up and it will no longer be ball bearing
and no they can`t convert it to BB iv been told
I'm not sure but do series 1 have BB?
Jeff.
Did you just get the compressor side hiflowed? It musnt be if u r spooling at 2500
I got both sides hiflowed ($1000) and im hoping for 200kw@12psi.
Starts spooling at 3000 full boost 3500
we'll see next week when i get her tuned on the dyno with the SAFC
Guest MFX_R33
My Hilux looks the goods, and has a nice tan leather interior, but it is no SR5 :D. Mine is a Grinner, ex-Repco delivery ute. Full time LPG, 1.8l, 4 spd. It's a slug but it looks ok for a work ute (pics on my site www.mfx.com.au under Team). Anyway I have a Skyline to go quick :D.
Jeff.
Jeff just looked at the pics of you lux and line the line looks mad!!
I really like the look. so different!
and your lux is great for a budget build as well.
how do you find the EMS is it as responsive as the the factory ecu how is it at low speed and rev's .
cheers
meggala
Guest MFX_R33
Thanks all :cool:
Meg. The EMS is good if it is tuned properly. I can't say that it is as good as factory. For top end it is great, you just need someone to spend the time to tune it properly for cold start idle etc. At the moment I still need to get the cold start tweaked, but aside from that it is cool. Other benefits of the EMS over PFC is the fact that you don't need the car to keep all factory or close to factory sensors, like AFM's (I still have mine on there but it isn't doing anything), plenum idle sensors, etc. I looked at a PFC but with the custom plenum and XF throttle body it was too much stuffing around. Also the amount of other options with the EMS is mind blowing.
Macka. I got the Trust bonnet from Bodyform motorsports in Sydney but it was for a GTR and I had to do ALOT of modifying to make it fit. The GTR bonnet, believe it or not, is 20mm longer than the GTSt's. The mounting brackets had to be moved as well as heavily modifying the bracing underneath so the thing would close! It still is no quite right yet as it sits flush top and bottom with the gaurds but it sits high in the middle.
Jeff.
MFX - just saw your hilux - nice interior.
Where did u get it retrimmed?? and how much would it actually have cost if you had to pay. My hilux has recaro interior and im thinking of retrimming them in leather and suede. Got any numbers I can call to find out costs?
thanks
Dave.
p.s - what did you use on the dash? has it been painted, or covered in leather.. or something else?
thanks. mfx's dash looks so nice. I gotta find out how he got it looking so clean...
currently my 4wd has:
single battery
k&n cold air intake where 2nd battery used to be
turbo smart boost controller (12psi)
autometer boost gauge
tinted (got that done yesterday)
and over the next month i am installing a stock r33 intercooler as a topmount where the old airbox used to be..
i am hoping for around 60+ kw at the wheels :cool:! but hey, they are 45kw standard so a 20kw increase would be good.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
