  • Replies 131
Now we just need to get Carlos and we have the old skool team northside dinner crew back together
You rang...
Geoff told me about this event, and I am happy to report that I am in! I shall dust off the skyline and come along.
Look forward to seeing the crew, I have not seen you guys in such a long time!!
you're not updating the list well nick!!! a few people have said yes, that aren't up there as attending :nyaanyaa:
Will have to confirm for myself closer to the date!! depends on work! its getting hellla buusssyy :pwned:
Now now, dont be mean Mona im busy as at the moment.
Dont tell me there is a chance you might actually make an appearance! ;)
Dont tell me there is a chance you might actually make an appearance! :pwned:
lol!!! yeah maybe! i don't eat beef though! so will have to check the menu to see if there is any tastey chicken on zee menu! :nyaanyaa:
lol!!! yeah maybe! i don't eat beef though! so will have to check the menu to see if there is any tastey chicken on zee menu! :whistling:
Moanie,
They have the best 1/2 or whole chickens in the world.
They also do pork ribs and seafood
Saw you driving what I presume is your new toy yesterday Andrew. I don't think you should cry too hard, your choice of car is commendable.
Guest Joeyz
If i may ask and i might be asking a bit much here.
Question to all Team North Side guy's an gal's. I'v only been with SAU for about 3months and still learning alot about it but was wanting to know how did you come up with this name and what is it all about. How long or when did this start? :)
Question to all Team North Side guy's an gal's. I'v only been with SAU for about 3months and still learning alot about it but was wanting to know how did you come up with this name and what is it all about. How long or when did this start? :D
Its a long story Joe, and started many years ago.
If your lucky we might divulge the origins of TNS to you on the night
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
