ive seen this happen. time for a tune up. your engine is not handling the thrashing well. could be a range of different things. depending on how exactly stalled. ie. as soon as rpm drop back down to idle state. or did it idle for abit then stall. EAch of these things signify different reasons and different things to check. speak to a tuner.
  • Replies 49
hey all
i hope someone ca help me solve this mystery.
the other night i decided to see how my car would go at really high speeds (now im talkin i got up to 170k) the car did well, held it togther nicely, but............i threw it into neutral to put less strain on the engine as i slowed down.........then she stalled. f*** knows why!??
Im thinking maybe it was cause she was at such high rpm????????? please help! this is so weird! cause the the highest i can go is 180 km so i dont understand why!!!!
170k,not cool would you like to see the result of 30k's over an comin un stuck
you's all act like you havnt done it before, which if you say it, i call BS
everyone does it atleast once, if there was no one aound her, no one in the car, she only put herself at risk which is just like if she where on the track
not that im saying i condone it
but just a note, you should have let the engine brake, i wouldnt clutch in/put it in neutral and then coast at those speeds, you want the engine to help you slow down.
NEVER EVER DO THAT AGAIN.....
This is what may have happened:
I don't know about R34's but in my R33, someone TOLD me that it has soemthing to do with my ecu not being able to correct the AFR with the blocking of the recirculation valve, or the unlikely event that too much air would be entering the engine, causing a stall, not sure how accurate that is.
Edited by Pauly33GTS-t
I agree with what Eug said. Its probably something to do with such a drastic change in load.
Are you stupid? Why would you do that? What was wrong with leaving the car in gear?
Have you heard of engine braking?
Sorry its just thats a really stupid thing you did. No offence. How can you be in control of your car if it isn't running?
the ecu made the car stall because it was reading too much air for idle than normal, thus f**kin up the AFR mixture and making the car stall, my guess. ie, the ecu couldnt correct it in time.
lol eh?
Edited by silverbulletR33
... are u from ns.com. go back there if you are.
I'll explain what I meant to say when I come to grips with what I wrote.
This is in a N/A section why are people talking about turbo's in the first page, is it a turbo converted NA?
The revs and the air flow into the motor drop far to fast for the ECU to keep up and causes it to stall, I'm guessing you probably have a vent to atmosphere BOV which doesn't help the situation either. Best idea just put it in fifth gear and brake.
My mistake, I got the wrong Idea from this...
CArs that do that. tend to be out of shape. Ie. need tune. clogged air filter. thrashed engine. dirty idle control circuits etc. the car should come back to idle fine. Not a big drama. but thats hwy i said 'Time for a tuneup"
but she had been tuned up only a week and a half b4 it happened. air filter was changed (pod filter), fuel injectores have been cleaned out. and a service ws done about a month ago (not even!)
anyway thanks everyone! its not something im gonna do again. its just not worth it.
you know full well that i'm not out on a personal vendetta or anything.
but i'm sorry to say no that you do not have full control of the car.
with the car stalled you have no power steering, and braking is very limited.
that aside, being in full control of the car still doesn't justify it.
i'm thinking oil pressure could be your problem? not sure, i don't know anyone else who would try/think to do something like that.
what the hell? power steering is done electronically...
turn your car power on without turning over the eninge and turn the wheel...
other then that, dont speed...
wtf ?
Anyways, My magna kind of does this. If i boot it and then throw the clutch in, the revs drop to like 200 rpm then bounce back up tp normal idle
hi ur car looks good but im so confused why would u put ur car in neutral doing 170 this is beyond me someone explain. anyway i would say that because u have put it in to neutral ur ecu is gone wtf and stalled and gotten confused and stalled. i say keep the 170 180 for the drag strip and please dont do that to ur poor car :D
but im not here to bag u out no offence intented
i had this problem while i was running a pod (only at high speeds is it a problem 80+)
i figured the AFM couldn't keep up with the rapid change in air pressure and it stalls because of that. no probs since i changed back to standard airbox
yeah i think its something to do with the massively high load on the engine, with it sucking heaps of air, then with no backpressure in the intake due to the poddy, the airflow has just stopped, or created some sort of random turbulence giving the afm an incorrect reading, causing it to over fuel/under fuel, or starve it of air.
anyway moral of story, leave car in gear :)
its all well and good people saying dont do 170 etc, but if she's in the situation where she needs to /can i.e. the track, it would be equally dangerous for the engine to just stall
hey all
nm
Edited by CCCP
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
