my mate got his 180 tuned by adam at jem and hes running a power fc and he like to do very safe tunes so id recommened him
also have another mate that has a ae86 turbo tuned by adam and also did him a very safe tune
Ben!
My car was tuned at unigroup - and alot of other members here have had their cars tuned there.
I am really happy with the tune so far!
12psi made 195rwkw but safely
only time I have had major knock was on the track and a hot day!
so other than that - she's been good mate
Yavuz and Adam are both very good tuners. I have nothing but praise for Unigroup as do many forum members over many years.
You will be happy with either and they're both very nice guys.
Post of the thread..."thats gold"!
Damn it I knew I should of done more random look at me threads with my motor in my falcon ute or look at my shiny new cooler piping through out the forum so people didn't forget me
wait wait I'll start now
Cover of Zoom :)
I would havehoped the tune would be safe for the track and hot days also. Have you had it back to them to sort it out?
Cheers
When Im out there I always use low boost to keep it safe anyway - dont have dramas with it then, just on the higher boost setting - with a shitload of heat thats all.
There was one bad batch of fuel which sucked also.
I did DECA on the weekend and highest knock was 22
I have spoken to Yavuz about it and he is more than happy for me to bring it in when I can
I just dont have the time and its a very minimal issue!
Cover of Zoom :)
:thumbsup::wave: fully sick got to love that :wave::(:thumbsup:
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
