I still love my Stagea but have to get some bigger wheels to fill up the guards.. it came with 17's..they look way too small..I know 18' fit with no probs but I am wondering how much bigger I could go (in total) before it would become problematic.I know I am restricted buy what will physically fit ...but a what stage would it start to affect performance/acceleration.
My logic tells me a larger overall wheel/tyre would decrease acceleration..and show a slower speed than reality...????
I am not thinking stupidly big....18's or 19's with a larger side wall profile is what I am thinking of.
Cheers
Scott.
https://www.sau.com.au/forums/topic/169024-how-big-can-i-go-wheels/
tub the wagon and run 30's, bling bling!!
(make it lower than grants too)
seriously however.. i know 235/35R18's fit, as thats what kylie has, and id imagine a 19 would fit easy with the amount of guard clearance there is left.
is yours lowered? that can affect rim size too.
also, larger wheels make you travel FASTER than what your speedo indicates, as the larger rolling diameter has a greater circumference, and travels a further distance over 1 rotation.
I know fuzzy had 19's on previously but now has 18's but im not sure what widths his 19's were.
On mine at the moment i have 18 by 8.5 all round but on my previous rims which were works on the back i had 18 by 9 and my Stagea is lowered also and i had no drama's
they were 19x8.5 ... fitted up easily without any probs.
Has anyone fitted 20's here?? I'd be interested to know how fitment went, well and what ride quality/fuel eco is like.
Edited by -FUZZY-
personally 17" are the best riding and most economic in terms of tyre prices. Once you get through to 18" prices jumped by almost 50%.
I found that 18" its ok and looks good. Trade off is the price and the ride quality especialy going over train tracks and shitty rural roads.
Perhaps Sk could clarify this. Between 17" and 18" tyres which one got more traction? In terms of pick up? My guess is 17" would fair better in terms of traction and pick u speed.
doesnt matter
my 18s have the same rolling diameter of stock
its all in your tire width selection and sidewall
Ill make it short and sweet
you have to answer two question
Do you want stock fenders and no rubbing
or
are youw illing to use a fender roller (or pipe) to flare the rears
and
is this purely for performance advantage
or
looks as well
Ill base what you should run based on those answers so i dont write another book
i've got a set of rims that measure 18 * 9.5 +32 on the way with 265/40 18's ..will tell you if they wayy too big when i get the wheels and fit them on.
easy fit.
id imagine 17's would have a slight advantage over 18's, due to a slightly larger sidewall, and usually lighter rims, and also majority of the weight being closer to the hub. however its probably not even noticable
aslong as you dont buy some cheap ass cast iron 19" chromies, you should be right. :)
doesnt matter
or
and
or
looks as well
easy fit.
it may have the same rolling diametre, but the rim itself is likely to be heavier, and have more weight further from the hub, thus affecting its ability to be rotated.
aslong as you dont buy some cheap ass cast iron 19" chromies, you should be right. >_<
so turn up the boost wimp.
if you view a 5 or 6lb a wheel diference a weakness.....then sure you can put it like that
everything has a trade off
wheels are a small amount of the entire picture
thats why d1 guys have more HP i guess
to pull around those big wide wheels, and all taht heavy aero and rollcages
dont forget wieght is one of the factors ehich is important in racing. In prro racing the would prefer to up the hp without upping the wieght.
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
