post-7531-1179660016_thumb.jpgpost-7531-1179660176_thumb.jpgpost-7531-1179660429_thumb.jpgpost-7531-1179660622_thumb.jpgpost-7531-1179660842_thumb.jpg[attac
ment=99205:102_1121.JPG]post-7531-1179661100_thumb.jpgpost-7531-1179661220_thumb.jpgwell it was an intesting night didnt realise i had to take my andra liscence with me so if i ran faster than 11 it was go home time since this was the first run since the new set up it tok a couple of runs to sort out the amount of power to use for take of. last run did 10.6 at 147mph not bad but still having issues with take of just frying tyres. and gotta sort out rear suspension might sell mymonaro if anyone is keen
https://www.sau.com.au/forums/topic/169423-my-10-sec-run-147mph/
Awesome!!!! U got too be happy with that time. Love this machine i think i remember seeing your car parked on orchird ave in surfers paradise one year i was up there?? Your gonna need some serious rubber under the guards next time, that mph suggest very quick times!!! Well Done
Go and see Kavey from KV's Resto & Race in Maroochydore. He's a Pro Street fabrication guru and will look after you. I think he's a bit flat out leading up to the Winters but he's definitely the man to see if you want the job done right the first time.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
