That's cool James.....shame it'll remain as a trailer & show queen and never be ridden cause it won't turn corners.
Here's another one similar to the stuff that Billy Lane from Choppers Inc builds.......these bikes do turn corners and can be ridden at up to 10 times the speed of that one.
Billy Lane argues that he made the 1st ever chopper with the hubless rim (external roller brgs).........very cool concept and makes wheel cleaning a breeze, lol.
Click link and see video at the bottom of the page:
http://www.markstechnologynews.com/2009/01...ys-amen-to.html
i had too google that car because of never seeing a RWD Hyundai and its actually a very cheap car in the states and has ok performance stats
dont mind these Hyundais. seen one a while back in Burn Notice ;)
Thats gay id kill myself, if i was seen on that bike or even a shitty harley
mate, if you appreciated the engineering that's gone into a hubless rim to drive it (let alone brake it) you'd be a little more appreciative of the concept
you're clearly entitled to your opinion re taste (or the lack thereof) but I couldn't resist biting with a trash statement like that
Bit hard to even begin to appreciate something that you've never ridden (if you could that is)............ask Roo how different a Harley or a Chopper is to a conventional sports bike
....and the answer to your last question is......... me, in a heartbeat!!
Poor Bird :/ , well shit happens. I seen a bird in the middle of the Southern Expressway that had been hit and still alive, it was flapping on the ground, wasn't a nice sight to see :(
Btw, those chicks aren't bad on the eyes :ph34r::P
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
