hi guys
i just want sum kind of idea wat power will i be making on my R32 gts-t. ill be goin for a tune and remap next week
my mod's are
K&N pod fillter
3" exhaust turbo back
Plazmaman Plenum
cooler 600x300x73
R33 GCG high-flow turbo
Z32 AFM
Bosch 040 fuel pump
660cc injectors
with these mods would i be able to hit 200rwkw+?
cheers
bill
Edited by JETR-32
https://www.sau.com.au/forums/topic/169795-how-much-kws-will-my-r32-make/
hi guys
my mod's are
K&N pod fillter
Plazmaman Plenum
cooler 600x300x73
Z32 AFM
Bosch 040 fuel pump
660cc injectors
cheers
bill
Bill, 200rwkw should be a piece of cake.
o plazmaman :) how was fitment? easy to install? did all the factory stuff go onto the plenum?
all the factory stuff went on with no problems. but the fitment was a head fu<k. had to buy alot of fittings and extra hoses etc.. and the plenum blots are not a direct fit u have to buy alot of washers hehe :banana: and get a thottle body cable made up. ill take a pic so u can see how it looks like. other that its running sweet no turbo lag and no cooler presure drop. it will improve mid and top end power
I reckon a fair bit more than 200...after putting a standard 33 turbo on a mates 32, with similar mods to yours - no injectors or plenum - it made 192 on 14.
Thats pretty much where i was a few years back. I made 175 on 12 so 200+ will be a cake walk.
im running a PROFEC B SPEC II boost controller on 10psi. but GCG tell me the turbo will handle up to 25+psi so if tuned rite i should be able to pump 2bar of boost in to it. i got my car dyno'd b4 i did da mods it was bone stock and pulled 117rwkw's
will post up dyno papers next week
cheers
bill
get a proper ecu not a remap to take advantage of the power.
you will probably get one in the long run so do it once, do it right.
with an ecu im thinking about the 210-220 on about 17psi.
i dont think it would be wise to be running 25psi through it.
  • 4 weeks later...
Okay guys I got my car tuned and not that happy.
Ok first of things the car was making good power on stock boost (turned off boost controller) 212rwkw's which the boost Crept up to 14psi.
As soon as Dr Drift started to pump boost into her she started to misfire at 16psi @215rwkw's and 569N.M of Torque, so we change the spark plugs to the v-power NGK and still didn’t fix the problem. Dr Drift said that as soon as I get Splitfire coil packs it should fix the misfiring. Which ill be going for another tune in a weeks time. Should hit 260rwkw's easy
ok now since I have been driving the car for a week i am having problems with my idle and the car keeps stalling and turning off. when the car is warm its not that bad it won’t turn off that much as it will in the cold mornings here in Melbourne. I noticed the hoses under the throttle body which just have coolant going threw them have been removed and plumed back somewhere else. could this be the problem for cold start???
and I have also noticed the car back fires heaps now, as soon as I back off it backfires. to rich???
and another problem when I punch it and do a race change it feels like it’s got a flat spot or surging???
all these problems where never there b4 the tune. could u guys help me out so I can let Sam know what to fix for the next tune...
cheers
bill
Edited by JETR-32
What plugs were you running before the tune and what heat range were they? I got my car tuned by Sam too and he changed my plugs to V grooved plugs with heat range 7...the car did not like it and idled like sh!t...i've since gone back to standard heat range 6 coppers gapped at .8mm and idle improved heaps...still sputters slightly but alot better...speak to sam...he'll know how to sort it out for you...
yea i had NGK iridium’s heat range 6 and gapped to 0.8mm idle was mint sitting on 800rpm b4 the tune. so after i get the Splitfire coil packs so i go back to NGK iridium’s plugs?
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
    • Really, low/midrange torque goes really bad?? I want decent acceleration, maybe I use a stock rb25det neo manifold?
