Ok so today i had my bin file from the CENTRAL 20 ECU looked at, and apparently it has no boost cut, and speed cut removed (knew that one) and 6900 rpm limit.
However what is happening, at 15 psi, the car feels like it is hitting a brick wall, and jolting, and then above 3500rpm takes of fine, no issues what so ever.
Below 12 psi, the car feels fine, a little retard posible but otherwise ok.
This ecu pulle 217 rwkw on my current setup, but over the past 4 months the car just has not felt right. I have done heaps of test for stuffed sensors and consults ect. and nothing there. Car usesd about one tak per 300 km in town.
The car developed a cold start issue, where as it started on 3 cylinders, cleared it throat, and then all 6 fire up. I have checked everything as per this post.
http://www.skylinesaustralia.com/forums/in...820&hl=cold
Can somone tell me what i might need to look for.
I will get the car tested soon, but need some ideas in the mean time.
HELP ME, AGAIN. LOL>
  • Replies 46
i had this issue when i tried a remap
i had a series 2 R33 and i got a s1 remap ecu and it ran like bozz
it was something about the MEC chip being the wrong one
sorry i cant be of much help. it was from a guy on the forums, tashi i think his name was
paul, wog's car's been working all this time. it's only now.
It sounds like it could be a spark issue like coilpacks or sparkies. I know you got splitos, but have you got new sparkies? what gap?
I remember reading a thread where people had problems with highboost and splitos. could be that?
plugs are relatively new, and gap is 1mm, i have had 0.8mm but made no differance, it is being a dog at low rpm not high, humm who knows, but it is certainly strating to piss me off.
oh yeah sorry Paul, the ecu has been in for ages and ran great, only last 4 months being crap.
Edited by WogsRus
Ok so i should have clarified eaven further.
The computer has been on the car for ages, and running with the SAFC II to bring the power up eaven more. The ECU is a generic one that is put out with Central 20 cars, so it uses all stock componenst and sensors, with new maps and so forht,
The car made in the current form, with Central 20 ecu and the SAFC II as per my sig 217 rwKw.
The car ran fine for agen but one hot day something went funcy, and every since it is hard to start cold, and the car feels the way it does.
The car WAS tuned in teh car with an SAFC II on a dyno, with perfect AFR's
The car was running fine for ages, say 6 months, only a recent thing.
Nothing has changes in the car mod wise.
DOES that clarify anything?
ok so i gapped the car down to .6mm gap and DAM it goes EAVEN WORSE. I mean below 4000rpm it's like a tracktor, the thing missfires and shit, compleat shit, and then bag wheel spin. I downloaded the rom and yeah i have no airflow limit, so the ecy should be fine.
What can couse missfire/splutering at low rpm.
This suxxxxxx.
Is it possible an airflow meter or a cam angle sensor.
Could it be a knock sensor?
HELP ME PLEASE
It'd say its probably the AFM, give it a decent clean and hopefully you'll see some improvement.
Otherwise the knock sensor could be faulty and making it run on the lower octane maps. Do you have a consult cable to check?
The plugs are 6's and are spot on to look at.
Yeah got consults, pickes up nothing. My voltage on the AFM at 750 rpm is 1.2V i think that is OK.
I did a log of the car this morning and noticed that as soon as it does this and goes funny, the oxygen sensor drops to zero and then bounces back then back to zero,
WHAT THE????
Probably just because its running so rich when it misses, if its faulty it shouldn't cause problems like that anyway. Nothing to lose, unplug it and see how you go for a day. It will run richer and use a lot more fuel at idle/cruise though.
have you checked your silicon hoses on your intercooler for small cracks or leaks?
i had this and the car flat spotted high in the rev range.
go around while the car is on and spray some detergent onto your silicon hoses and see if it bubbles up anywhere.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
