There is a buyers guide Stickyed up the top I think.
My tip... look out for rust behind the door mirrors.
what is your petrol economy like how many l/100km i am going to be driving it every day to run a mobile service
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3143836
Use the SEARCH button. I have and this is what i've come across.
Driven carefully i.e. off boost most of the time with engine running well-
Around town 14-15l/100km
Highway 10-11l/100km
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3143853
haha and what should he do when he finds it? because its pretty definite he will.. :stupid:
Haven't seen a stagea without the TINY spot of rust behind the passenger mirror. Not a big deal at all - just something to be aware of. So saying I still haven't done anything about mine, after 1 year of owning it...
it shouldn't put you off buying one. Stageas are VERY reliable as you can tell by the lack of requests for help fixing problems on this forum. Most "help me" threads are self-inflicted in some way, and by that I mean that very few problems would relate to a stock stagea :laugh:
Edited by pixel8r
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3143944
I got mine removed and resprayed when the bodykit was done. I belioeve that would be the best way to do it. And sometimes that patch of rust can be bigger than you think, pull the mirror off and have a look first. Not in all cases but in some it can spread.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3145048
Defiantly get a compression and leak down test if you can, it'll show you how the actual motor is faring after 8-10yrs of use.
Basically same things as a skyline, if you can looks for shaft play in the turbo as well.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3145236
You can buy bottles of rust inhibator from hardware stores.
If you are after a quick fix for the rust problem, you could just brush this on under the mirror and inside the door. Then when it's dry, put a layer of paint over it.
Should stop the growth of the rust spot for a few years
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3145900
cheers, thanks for the info!
its been on my "todo" list since I got the car (um...about 14 months ago) - really need to get onto it...
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3146261
  • 2 years later...
I let mine go and the rust spot turned into bubbling paint about an inch under the mirrors. After purchasing, rust proofing and installing two doors my advice is don't wait. Do it now.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-5168995
check under the boot seal too,stageas love to rust there also a couple of guys have had trouble with rust under the roof racks. i hit mine pretty hard with a four inch grinder then rust converter until its all changed colour ,then paint it. Also the electric mirrors can be problematic once they get older but its just a case of pulling them apart and cleaning them up a bit.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-5169118
You can't fix the rust under the mirrors problem from the outside. There is a good tutorial on pulling off the door cards and pulling out the bit of foam that soaks up water and either replacing it with something water resistant or drying it out and waterproofing it.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-5170518
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
