  • Replies 71
Originally posted by Ronin 09
Funky, i make t shirts. Let me know if we can help - my label is 'i/o style'
www.iostyle.com.au
umm, but the site is not up yet... lol
here is one of our tees:
Hey, they ain't bad... i see a SAU member in there too.....
I'd buy some just for general wear!!!!! :D
ALSO... do we need helping hands ?
I'm not putting the beast in but i cna lend my handi work !?!?
lol dont get too excited boys
im gonna be managing the models
keep em in line
make sure they dont wander off
black tops
low cut at the front with shans designs would look absolutely great
with a nice black skirt.. or low cut black pants.. whichever the girls prefer
we are going for a classy yet striking look.
as for the sau crew.. we have other ideas for their outfits :D
guys if u know any absolutely gorgeous girls please speak to them for me and let me know if you could possibly hook tem up fo as much of the MAS weekend as possible
i will organise a lil meeting with the girls
once we get them all together and go through with them what they will be doing.. oohh yeah let em know they will get their nails done by kylie as well!
their will also be miss auto salon and bikini contests so please make them aware of this also as we would love to be repesented in these comps !!!!
NO PROBS LEEWAH...
UR CAR IS GONNA BE IN OUR STAND YES??
as for oly gorgeous girls allowed..
hell yessss
we dun want no skanky looking 16 year olds from frankston
unlike some other clubs... *cough cough*
haha
the girls play a major role in the stand of course
posing for photos.. attracting people to the stand
they will also be walking around promoting the club
so we need some headturners thats for sure
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
