Sandown Sprints This Sunday - June 10th - Driver Training Only $90!
  • Replies 127
Posted Images
Oooh. I have a new box with suspension waiting for me ;) Hopefully that will be enough to hold off the onslaught of Silvias/180sx etc in Mod RWD.
Winton has always sucked for me, have never got a lap in which i woudl say was even 70% right...but think i will still struggle against some of the other guys there. Time will tell. Club Championship will be updated shortly.
Will you be set for Winton?
I hope ill have mine ready.
Nah, no chance unfortunately. It's on the weekend I get back and I've still gotta spray the engine bay and put the box in, as well as fit the engine and get it tuned... :)
Everytime I think I'm nearly there it seems to get a little further away...
I love the video Camera, it shows me exactly what you get up to HANDBAGS on the parts of the track I can't see!!
Poor Lil Blu.. She's been good to you, be nicer to her!! :D
Maybe Adam should show the 'In Car' footage at Turn 1 at Winton on the weekend...... It's certainly not quite as scary but still entertaining.
Who's car was that in again? It wasn't mine!!
I never new GTR's could drift....
You should have punched the throttle and held it to the next corner...
Hahaha once apon a time I would have but its been a hard task to learn to correct mistakes not embrace them.
Here is some more footage.
lol :laughing-smiley-014:
So true.
Fera not Troy, i heard a birdy telling me someone is getting decent tyres for their evo :D
