  • Replies 104
when you get it tuned, get it tuned to only run rich in the topend which is when you need it to run rich, off boost your car shouldn't have to run rich as its not under load and shouldn't detonate, mine bad on fuel because its always rich, even on idle i can smell fuel
YES.
the cruise maps are in a completly different area to the boost power maps and you CAN have the best of both worlds.
Its just that people ring up all the dyno tuners and find the CHEAPEST tune they can drive there car in there with a new unmapped power FC get a few power runs get the max power the can in 30 minutes to an hour then pay there $250 for their tune and drive away with really bad cruise maps.
When i tune a car i spend more time on cruise then i spend on boost. I like my cars to have good fuel economy and driveability as i tune them like i tune my own car.
Its the difference between a $200 tune and a $800 tune. You pay $800 for a tune from UAS because the TUNE THE CAR. Not only just boost the car up to make it fun to drive.
Thats all there is to it. Also driving habbits have alot to do with it. sometimes on my drive home (60km's) i dont go over 10% injector duty.
ok stupid question, remember i dont kno much about turbo cars, when i get a tune done for it can i basically say to them look i want a mix of good kws and good fuel milage? or what?
but surely someone like boostworxs would kno this without having to say anything??
yeah cars that are tuned badly on fuel are usually just tuned on WOT, wide open throttle, which is stupid as people spend most of their time driving normally and need a tune for that, good tuning makes all the difference, in my old car i had a microtech which people know are usually uneconomical, but my tuner tuned it at every rpm instead of just at WOT and i was getting 10L to 100km's with normal driving and still pushing decent power
It goes like this. you take it to a workshop where they are going to tune your car for you for $150 - $250 then your going to get shit fuel economy.
You get what you pay for. Pay shit money and no time spent on it and get a shit tune. I have fixed cruise maps on power fc's from various workshops. The workshop is not paying the fuel bill are they ? why do they care?? they dont give you a print out of your fuel economy with their business name on it they give you a power print out and most of the people are "gees thanks man thats great power thanks for doing such a great job on my car"
lol makes me laugh...
Yeah, a good tune with economy your looking at a bare min of $500 before you start. Upto 700-800 quite easily.
But do the math, the economy of an extra 100-150km's per tank makes a difference soon enough.
yer thats wot im thinking petrol in adleiade today is $1.35 so yer makes a big differance.
Just while were on the subject anyone used slides turbos? what they like? do they last? and put out the claimed power?
what kinda management can this kinda economy be achieved with? i own an auto and i know that the simple fact of 1 less gear means worse economy. it also means i cant use a standalone ecu (eg pfc). im guessing somtthing like a safc is not gonna cut it right?
stock computer can get economy but not as good as a PFC. try a HKS F-CON and get it tuned in sydney
prefer to do it in melb. thanks for the reply tho :worship: will look into the f-con. im getting crappy economy atm. car is dead stock - just a 3 inch catback, hi-flow panel and constant 7psi (eliminated the factory 2stage) at 159rwkw and i get about 380-400ks.
if some of u guys are getting 100ks more with about 100kw more power then i figure i need a tune
you cant get a f-con tuned anywhere but sydney or perth.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
