As you most of you know, my GTR was broken into and 'stripped' just on 2 months ago. It was obvious the car had been followed and targeted. The windows were smashed - and the alarm didn't go off. I live in South Yarra.
One of the many items stolen were my old number plates - GTR-88.
Well...
I was sent a PM from a guy on the MCCR forum asking me if I had my car back, and was it white - as he saw a white Skyline with GTR-88 plates on Dandenong Rd, near Chapel!
It gets better...
https://www.sau.com.au/forums/topic/17088-car-break-in-getting-interesting/
  • Replies 77
It just so happened that his car was broken into the other night. In South Yarra. Same deal - window broken, alarm not set off - they took his Apexi gear... but he saw them doing it and chased. He got a partial description on the car and plate:
White import hatch (GTi-R, Charade, Starlet, WRX etc) with loud exhaust and plate something like 'TURBRO'.
View the MCCR thread here
I noticed in a thread here that Chop saw this same car near Chaddy!
I'm not sure if these are connected... but I rang Prahran police anyway. If you see either car - GTR-88 or TURBRO - call the cops.
Pretty stupid to be driving around with stolen plates..
Good work P.D. James :D you are well on the case!
Lets hope this scum gets caught, and the cops can actually do something to help out in this situation. Amazing, real crime to be policed.
Ah - it all makes sense now :D
Must have been the smell of pancakes impairing my judgement.
Do we have a confirm on the car - GTi-R?
See it has a titanium Nismo shifter. Grrrr.
Gordo - Haha. Just call me Jessica Fletcher.
yeh it mite of been white gti-r or starlet
it was dumped low on its ass
big 3.5" stainless steel muffler on the rightside making very loud sound
multispoke rims 17" or 18"
black personalised plates with "TURBRO"
pretty sure there was bonnet vents
driver was some tall skinny white guy, window half down, wearing a dark coloured cap.
hope that helps
would this be a joint mccr and sau club bashing? cos me and boys in the sig want in!
I remember seeing those plates around the S.E. suburbs myself... don't remember anymore details on the car though. Will keep an eye out.
I'll put my name down for the lynching mob too! People stress when they see a 6'4" guy step out of his Skyline...
carry a crowbar, and if an officer asks what its for, say its ur lover...or something
anyway yes i will keep eye out also but im in northern suburbs but do a lot of deliveries everywhere in the work truck, which means i can run them off the road or throw glass peices like shurikans at their necks
i rule
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
