I'm in.
Duh lol ahahaha :laughing-smiley-014:
you are already up there my little BTR friend
Now for everyone that has confirmed with me and name is at the top we need you there by 10am if you can get there at a better time like 8am to help us get everything ready that would be great.
brief starts at 1015 and then off you go.
I personally believe an entrant can not judge...has to be inpartial. Am I wrong or something?
EUG.
is there still going to be a mankini contest!.?.?.?.?.!
So whats the goske's about entrants being judges?
Personally i think that it's allrite so long as the car isnt judged by it's owner.
I think the idea is that you can't judge the category of car if you own one. For example, because I own a Stagea, I can't judge other Stageas because THAT would make it biased...
EUG.
Who cares who judges and who cares who wins. At the end of the day it's only someone's opinion. You might have the best car but there will always be someone that thinks its not that great. Some people go for the race look, some people go for the show look.
So many people tell me my car would be better with this and that and everything else.......at the end of the day I picked everything on my car and like my car (most of the time) and thats all that matters.
Either way we'll all have a great super fun filled day. :yes:
Note: I may not be having such a fun filled day on the long drive home :D
Its all for fun and Judging is done by committee members for the show n shine sponsors and some members. If we need more then it will be that we need more. But there are some ground rules which the judges on the day will be told.
FUN is the name of the day
If you need paint quality inspector I'm your man, if not I'll be havin a few & boppin to the beats of DJ BRAVE, he rocks. :)
Well I am not sure what is going to happen this weekend but we could always use da'Man for the job :thumbsup:
can i be a judge too? best smashed kit...i'd probably win that hhaha...got the stitched up face and skirts...might reverse my rear bumper into an atm to ..hmmm......
will be present at the event for sure so would freely accept role as a judge.
Can all the Judges please confirm that they are coming please as we need all judges ready at 10am :P
Adam Ownes R34 GT-T
Jess Ownes R32 GTR
Nick Ownes Stagea
Chubs Ownes R33GTS-T
Blitz Ownes R33GTR / R32 GTS-T
Craig Ownes R33 GTS-T
Paul Ownes R33 GTS-T
Corinne Ownes R32 GTS-T
TJ Ownes R33 GTR
Nick Ownes R32 GTR
Smokenhowzen Ownes Nothing? HAHAHA Ownes R33 GTS-T
Vic R33 Ownes GTS-T
WTF33R Ownes R33 GTS-T
Me Ownes R33GTR
Ben-m Ownes R32 GTR
Trust 33 Ownes R33 GTS-t
Silver-Arrowz will be judging
Endorean (MATT)
Stuart from Pro Coat
Craved (Chris)
Merli
someonestolecc (TOM)Project Mayhem r31
I know Stephen ( DRIFT KING)skylinegtts
Jetr32
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
