yes, well pending trailer and truck to tow it with i'm in. will need to reschedule a few things. but i'll give it a shot.
Rev it up sounds like a wishy washy. Pull you zipper around the front will you. Has someone infiltrated Beer Barons password and did this Miss Daisy post? Give me the real Beer Baron.
When the guys came up front Vic to go to Eastern Creek which is a nice track but no where near Phillip Island and 90% drove up to see the sun and go to our track, and bunch of them to. Hey Snowman how many were there of you by the way?
GTR Jason, Abobob got your ears on and Paul Lewis??
Edited by Boosted Zed
  • Replies 263
Posted Images
Stig, Aaron, Scotsman, Golgo, Dances with Fences, The Vag, Nige and Riverdance all came up to drive at EC. A couple of others drove up just for the social aspect too.
Half the fun of a road trip is the drive :)
But Barron went limp recently with a trip to Shepparton so the extra distance to the Island it asking a bit much.
Mate if I can get a hold of my mate's 3 car transporter I'll bring both, otherwise I will tow the Evo down :) Have been told on numerous occasions to get my arse down to a track day at Phillip Isalnd, & this fits in nicely....
Re Jeff, sounds good!
Cheers Cam
Spoke to Uncle Jeff today and he said he'll come down for it. So Nissan v Mitz is on :)
don't worry pansy's. baron is all man, baby. zipper is on the front as always captn.
i'll get my shit together for PI and see if I can't go down in a blaze of glory.
Hmm might have to ship my old R32 back to OZ just to join in...or buys meself another to play with in OZ
not sure if i can get back to Australia to watch, but i have a place about 45 minutes from PI if i can get back i will open up the joint for SAU members for a place to camp
  • 4 weeks later...
haha, that could be an option. what do you think about making your patrol into a b double and run two trailers on it? should be fine, it's dealt with worse before.
fats is in and best track with some top cars and hopefully Giant will coem from Qld and Beer Baron are you beer talking or coming to this ?
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
