Had a good time watching all the cars ... was wondering what some peoples results were ... the best i can remember was most skylines getting 13's ... martin soarer doing low 13's ... an old school skyline doing 15's (about 45 times too i might add :P ) ... and excel in the low 13's ( i wonder whats under the bonnet??) ... that red rotary drag car doing a 9 something and made me deaf ... keirs 32gtr with a 10.42? also made me deaf ... lots of commies in the 13's 14's ... falcon with a 12.9?? oh yeah ... evos with low 13's and 180's in high 12's??
correct me if im wrong ..
https://www.sau.com.au/forums/topic/17154-drag-results/
Very nice times there man! It certainly looked the goods.
The whole car was twisting and rocking at the 1st/2nd gearchanges - I was sure something was bound to snap with all that force/grunt! What mods do you have? Did you import the car yourself or is it local realease? (not sure if they sold them here or not).
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355002
my friend with me has an evo4 ... he didn't race it and it was parked outside with next to my car ... it used to be 224kw@all 4 ... that was with a hks turbo ... and motec computer tuned by rpm ... he never races his car though ... hes since taken out the big turbo and made everything stock agian ... lookin to sell this evo4
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355087
Good to see everyone out and finally put some faces to names.
I did 13 passes and my clutch didn't even stink on the way home!! Even though the commentator (Andrew I think) thought I was trying to fry it, with so many runs in a row.
The track was bloody slippery at first but good to see some nice rubber laid down throughout the day. I finally broke into the 12.4's running 15PSI with a 12.421 at 110.26MPH (60' 1.835sec).
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355619
Great day, thanks Ivan & crew from RPM. First time I've ever done it and was good to drive home OK (apart from a now leaking exhaust manifold that I'm told is no big deal for a while!).
13.42 ET, 106.5mph, best 60' was 2.11s.
Main thing is that I beat grepin, Chris32 and Bugalugs :burnout: Dare I say quickest GTS-T on the day! Bugalugs' run were amazing though, 13.44 I think and 106.99mph!! And that's with a stock ECU...good stuff.
grepin, do you now surender? Do we declare WW1 has been won by Freebaggin .... or should we wait until after the climactic battle this Sat at Tilbrooks for the outcome of WW1?
Then WW2 starts soon after!
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355737
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
