Hi,
I have just pulled the gearbox out of my r33 gts-t so i can install a new clutch however i cant get the bolts undone on the fly wheel so i can go get it machined, has anyone got any tips?
The car is in the garage up on car ramps so i dont have a whole heap of room to move a crack bar...
I have tried using an impact driver but still no luck..
On all my previous cars i have been able to get the flywheel off, but this one just wont budge...
If anyone can help it would be great.
Thanks,
Scotty.
https://www.sau.com.au/forums/topic/171873-flywheel-removal/
no trick to it mate, they are just tight. If you dont have a ring gear stopper just put a bolt back in and use a pry bar in the flyhweel teeth to hold it, then biggest breaker bar you can find.
can you get the car up any higher?
Some people recommend that you hit the flywheel bolts with a hammer, then try the breaker bar again. I used the approach on the three stuck bolts on my car and it worked, but i'm still not sure its a good idea...
Tapping the bolts with a hammer is a good move on anything, wont damage anything. One firm 'tap' can ungrip any threads that have started to bond which would otherwise make it extremely hard to get loose with just a breaker bar.
Edited by deant1
Thanks for your help guys,
Since the rain has finaly stoped i have been able to get back to working on the car.
I did get the flywheel off, i ended up giving the bolts a good "tap" with a hammer and used a longer breaker bar.
Although i will be replacing the bolts as 3 of them have started to twist at the head.
Thanks,
Scotty
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
