Hey guys - got a problem to report - wondering if anyone can help out.
Last night me thinks - it's cold, 0.9 bar is going to be waaay safe so I dial it in and plant it in fourth. At this point a few things happened - which have happened before:
first boost comes up - ok, all good
then suddenly everything cuts completely for about half a sec - felt like I'd turned the key off!
then it cuts back in...
then it misfires around 5000rpm - which I'm guessing is the plugs and I'm hopefully going to fix that problem today...
the first problem of the engine/revs cut I'm thinking is the AFM going past it's voltage limit and shutting down.. does this sound right? what can I do to fix it? I've sprayed/cleaned it with heaps and heaps of electrical cleaner which didn't seem to make much difference..
Any ideas?
https://www.sau.com.au/forums/topic/17194-afm-problems-i-think/
Caminperth,
I had the same thing happen to me when I had my car at about 13psi while mucking around. It was fine on the dyno but as soon as it was on the road it would start to have the problem you described.
The guy told me that it would be even worse on a colder day due to the fact that there was too much air getting into the engine and the air/fuel ratios where not adjusting correctly on my stock ecu.
A SAFC would probably fix your problem, I have a simple Pivot air/fuel meter (1 universal setting) and adjusted it to make it a little bit leaner and it has fixed the problem for me.
I am no mechanic/tuner so it is just a suggestion ;)
Daniel
aidwin - as you said man - it's not the speed cut..
b005t - yea - i know what the speed cut is like and this ain't it. :rolleyes: and yea - am still running stock cooler...
adrian - could be - but it's fully intermitent..
bam - i wish i could afford the gtr!
daniel - i've got an afc and itc (old skool apexi fuel and ignition controllers) and that should sort out the fuel issuses at higher boost...
i fixed up the plug issue today - tho can't really try it out in this weather.. :)
still at a loss as to what it could be.. still got an inkling it's the airflow meter maxing out... will do it more when there's cold weather due to more air due to the density change... sound right?
Cam,
It's the boost cut/fuel cut. The boost controller has nothing to do with it, it's the AFM that tells the computer when it senses too much air flowing, which means too much boost, and it will hit boost cut, resulting in a nasty sudden halt to the car:D
You'll need to replace your ECU or get a fuel cut defender to stop this happening. It is worsened by the fact you have a stock cooler, and cold air is denser, thereby the AFM senses more air flowing:D
Hope that made sense (and is true)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 馃槀 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
