Hey everyone,
I dont know if you guys have heard yet, but Newcastle got hit by flash floods yesterday! THe water levels rose so high....cars were floating down the street. Unfortunately i was stuck in grid-lock traffic, with no choice but to drive through a rather deep section of road....1 metre 'rather deep'!!!..... I was lucky to get home! As a result my pride and joy is misfiring and carrying on! It idles ok....starts to rev ok....then, all power just drops out/cuts off...then trys to pick back up again! ....not happy! :)
I obviously figured, i managed to get water in the intake (seeing as though water was washing up over my bonnet!!!)....so i started to pull a few things apart to see how far the water got! The air box had a fair bit of water sitting in the bottom!.....the piping from the air box to the turbo was damp!....the piping from the turbo to the intercooler was damp! (which means the turbo must have got water in it! F$%K)....the intercooler had a bit of water sitting in the bottom of it....it also has a greasy/oily film through it! (im thinking oil from the turbo!).....the piping from the cooler to the engine-intake was only slightly damp....and fortunately (and about the only fortunate thing about all of this mess!) is that the engine-intake (just before the throttle butterfly) looks relatively dry!
Ive taking everthing inside...in an attempt to dry it all out....but i really need some expert advice ->
1) what damage may have been caused?
2) what if water is still residing in the turbo?
3) what should i do with the intercooler? How do i clean it out?....i put a hair dryer through it and the air velocity seems to slow down from one side of the cooler to the other....is this normal?
4) What do i do next? How will i know if there is damage i've over looked?
I plan on putting everything back together this morning....so its kinda urgent....any expert advice would be much appreciated!
Cheers
https://www.sau.com.au/forums/topic/172128-help-flood-water-damage/
I think all you have is water in the electrics. Water in the intake will stop the engine dead in its tracks as it fills the cylinders with water.
If you can, get the car under cover, spray the engine bay with liberal quantities of WD-40 (or similar), and let it dry naturally. You may need to disconnect and inspect every connector in the engine bay to ensure they're all ok.
yeah sounds like you've got a bit of water sitting around your spark plugs. take out your coil packs and check for any water that has ponded in the spark plug hole. dry up as much of it as possible and it should run as it did before.
Cheers guys!
After a great deal of stuffing around....ive manage to pull it all apart and put it all back together again (drying everything as best i could in the process)! Other than the water found previously....there was a 5cm-10cm well of water sitting under the ignition coils!
Its been a long day...i really need to sit down...so long story short it started...blew a little white smoke (water in the exhaust?...oily film in the intake?) and seems to run ok! :) However there are still some unresolved issues :-
1) I can hear a whining noise coming from the engine bay...perhaps a bearing? but dunno what one?
2) occasionally i can hear a kind-of-belt-slipping sound
3) When i run it through the entire rev range....up high (around 5-6k)...occationally it hesitates a little. Not sure if this is water still effecting electrics? or perhaps some crap goin through the intake?
4) Seems to run intermittently smooth then a little rough? (maybe even missing a cylinder occationally?)
5) Dunno if all my sensors and electrics are ok or not?
mate it will have been wet coils for sure, you are pretty lucky - like blind_elk siad you can sieze an engine if too much water gets through the intake, and you probably wouldn't be covered on insurance.
Dry around the spark plugs, leave it a few more days and everythign should come back fine
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
