who in perth does it ? is it worth me getting it done atm when i plan on getting SAFC NEO and a EBC soon (soon means a few months :rolleyes:)
current mods r
stainless 3"intake pipe with pod
3" turbo back
FMIC
thats bout all that would effect engine i think :S
https://www.sau.com.au/forums/topic/172199-stock-ecu-remap/
no point tuning your car 2x times.
i know for tuning safc its like $150-$250, i would guess retuning stock ecu would be more like tuning something like a pfc so you will be looking at $400-$450 (just a guess)
And if you retune your stock ecu then there is no point in getting an safc.
safc is a band-aid , quick fix, retuning stock ecu is just as good as getting a full ecu
Cheers michael
https://www.sau.com.au/forums/topic/172199-stock-ecu-remap/#findComment-3170989
Cheers michael
ooh ok i didnt realise that, might not bother with SAFC then ?
hmmm or i might, if its cheaper to tune it might be better :rolleyes: seeing as i plan on getting injectors and fuel pump and then cams and cam gears
https://www.sau.com.au/forums/topic/172199-stock-ecu-remap/#findComment-3171020
if you plan on getting injectors, depends how large you go, the safc may not be the best opinion, as i know you can run larger injectors but the larger you go the harder it becomes to get it to work right. Also safc does not do timing which if you plan on going further with your mods you want to be able to adjust the timing through the revs etc
Althou if you buy the safc and get it tune with what you have now (so safc cost $200 + $150 tune), and changed ur mind later on you should be able to sell the safc for $200 and you just lose out on the cost of your tuning which isn't too much.
Cheers Michael
https://www.sau.com.au/forums/topic/172199-stock-ecu-remap/#findComment-3171047
Cheers Michael
thanks heaps for the input mate, will keep that all in mind :rolleyes:
i dont plan on going too crazy though, only 550cc probably bosch 040 (or 044) watever the intank one is, cams and a highflowed RB25 turbo
https://www.sau.com.au/forums/topic/172199-stock-ecu-remap/#findComment-3171065
safc should be ok to do that but you won't get the best out of your setup :thumbsup: as its only a quick fix...
unfortunately powerfc for r32 are hard to come by (need to get the AP type) so there is no real cheap full after market ecu for r32 :cheers: so maybe a retune of the stock ecu might be your best shot! Their is alot of heavy mod. cars going around with just a retune stock ecu (for example there is a 9sec gtr in japan running stock retune ecu)
Cheers Michael
https://www.sau.com.au/forums/topic/172199-stock-ecu-remap/#findComment-3171073
Cheers Michael
yeh i noticed the 32 PFCs are hard to come by and expensive, that sounds nuts about that GTR haha, well sweet, sounds like u made up my mind for me :rolleyes: cheers ! guess ill just get the HKS EVC V and no fuel piggy back, thanks a lot :mellow:
https://www.sau.com.au/forums/topic/172199-stock-ecu-remap/#findComment-3171095
according to this lumpy is no longer tuning outside of autronic and special stuff
http://www.westdrift.com/forum/viewtopic.php?t=1176
"Yes, it is true than i am not tuning for the general public anymore.
The only work I do in this area is with regards to support/supply/install/tuning of Autronic products, for which I am the dealer in WA, and I am also getting heavily into the data acquisition side of things.
The push towards a greater profile in professional motorsport occupies me these days, with 50% of my time spent interstate and some overseas stuff not too far away, with the management and ongoing development of the Slide-FX Pty Ltd drift racing team and it's in-house projects taking up what's left.
Thanks to all for the wishes and previous custom."
https://www.sau.com.au/forums/topic/172199-stock-ecu-remap/#findComment-3174963
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
