Hi guys
I have a '96 gts-t, which hs just started playing up tonight. When on idle it will sometimes 'hunt' usually upwards the sometime splutter and die this is only occuring when i let the car idle. Driving around it's fine until I come to a set of traffic lights. Car has had no mods for the last two weeks, so its nothing I have done.
I suspect its a fuel filter or pump.
I pulled into the servo to top up with fuel just incase I was running too low, and I noticed the fuel filler neck looked odd. Is is possible for someone to post a pic of their fuel filler, I have a nasty feeling the filler has fallen into the tank and caould be causing the problem. But 'm not sure, is it even possible?
Can someone with a 33 please help me out, and post up a pic.
Thanks
Nick...
Edited by stolen_s15
Thanks for the help guys, i'm pretty sure the brass bits were there before. It looked odd when i put fuel in, but i wasn't sure. When I fish the little f_ck3r out will i need to glue it back in or anything, or should it just clip in?
Also has anyone ever heard of this before? Or is it a new one for the skyline medical journals?
Looks like your going to have to do battle with the big plastic nut on the top of the fuel tank to get the bits out. May the force be with you, and failing that a nice strong lump of wood and a big old hammer.
Ok, compliance pisses me off. They stretch your fuel filler neck to fit that spastic brass thing in. This means that your petrol cap won't seal properly against the filler neck anymore without it. Downright pisses me off, because those stupid restrictors always come lose after time.
If mine ever comes lose, i'm going to source a filler neck which hasn't been 'complianced' and replace it.
leave it out... its the first compliance thing i remove on all my cars.... im lazy and hate having the unleaded restrictor in there especially when filling up at the airport :)
So does the filler cap not create a proper seal then? Wouldnt you get fuel splashing out when going around corners??
I had an issue where my filler wasnt sealed properly, and it spills fuel all over the track when i'm cornering hard..
It won't seal. Your tank cap seals against the filler restrictor - correct? yes
Therefore, the restrictor's cap opening is the same size as the original - yes.
I know because I watched the pricks comply my car. They used this air tool that expands the opening. They use a little bit of that squishy metal stuff. the metal glue that you squish in your hand until it becomes warm, then it sticks.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
