  • Replies 539
after looking at those last pics of the engine dismantled etc i seriously can't wait to see this all put together!! I especially wanna see how the white painted covers look in the bay (hope you're cleaning your engine bay while it's empty too!!).
is it weird to get hard looking at engine internals/parts?
you should see whats air brushed onto the engine cover :):banana: ........thanks for the reminder i knew i had to clean something ..what do you think the best thing to clean it with besides elbow grease :O
airbrushed....oh you didnt..... how could you?!?!? haha i suppose each to their own. maybe if it was something reaaaaally tacky like zebra or leopard print i wouldn't mind it - but you've probably done a silly 'graphic' of skulls or something haven't you? haven't you!!?! come on, lets see it.
degreaser for real grubby parts or just use car wash stuff probably. and yes, ample portions of elbow grease unfortunately.
skulls are for novice ive gone one big step up from that ive put the cast of high five on it having a orgy with teletubies .......perfection what do you think.
boys....boys the key word is save your money and it will happen for you it took me a while to save the money $60 a week for two years plus my tax money for two years plus selling shit on ebay putting up with dickheads and just knowing what you want and doing it and giving up smoking and having more money .,and having good friends to help paint things and air brush things and build engines for you..so anyone can do it ive been doing it that way for a long time so all i can say is if you really love something than just do it.....even if it takes 2years
sitting down waiting for things to happen does not work
EG.
Edited by WARLORD
Have seen cam covers painted like this, in various jap color schemes over the years. Looks ok but its hardly original.
Thanks for sharing the build tho bro, well done.
o well there goes that idea of being the first thanks for your input :/
maybe first in oz.... maybe.. can you supply some pic of the ones you have seen.
great job, nice work, Cover Looks awsome. I bet your excited. I know i would be.. Lucky man! I feel intimidated somewhat, knowing that beast could be lurking around on the street real soon.
good luck with the build, HOpefully all goes well..
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
