  • Replies 539
full boost is in the high 3k 3600-3800 i don't know why it looks that way on the dyno sheet but its way earlier than 5k.
also for every ones interest my mod to the air box is real dam good dyno run with the box and without was the same,we took the filter out and ran it and put it back in and it was the same power.
so my gamble was 110% right.
Edited by WARLORD
Ah ok, thats interesting.
The dyno is indicating a powerband from 120-180kmh, so 1/3 of the rev range (roughly). If you were to do it basically 8200/3 = 2733, x 2 = 5466. So the sheet is saying its on power at 5500 if its revving to 8200.
Is it possible that graph is for a lighter ramp rate or something like that?
on the ecu maps its set a 9000rpm as i have just looked at the tune so i have NFI why or what id love to really tell you what i think at the moment its easier if i just pm you about things i also have haltech reviewing everything as we speak online.
yes you are correct 4820rpm full boost of 23 psi the build up is so fast that you could swear its much earlier its tuned in ve mode (volumetric efficiency tuned)which is new to me.
That's good power for 98. I'm guessing its on full pelt about 5k? When does it start to get urgent?
Edited by WARLORD
Your setup is screaming for E85 Nick, that turbo is capable of making big numbers for its size.
I think 35R size turbos and bigger are wasted on setups that run moderately low boost levels. Chasing response is not really a goal anymore and you will only get frustrated doing so.
Very nice power but I am so far fairly disappointed with the lag, feeling reasonable considering how late the turbo comes on is more of a credit to the rest of the setup in spite of as opposed to thanks to the turbo. Unless there is a setup issue responsible of course, that is definitely laggier than just would have expected!
i think its probably normal for a gtx of that size, my gtx3076 on 98 was a late turbo, 18psi at 4000rpm but probably 4400ish til the back tires broke free.
E85 and more boost helped alot, but would do on most turbo's anyway.
Edited by AngryRBGTX
disappointed nar its not that bad it really doesn't feel laggy honestly has anyone else had there car tuned on ve cos ive been in cars with lag but this feels different it could be set up.in the top end you see the torque drop of it was explained to me that its cos of the cams need to be bigger tuning in volumetric efficiency calculates the amount of air that can flow throw the engine and cos the head is ported the cams are my restriction ..............true or not i have NFI..lol thats the only set up issue that i can think of
That's odd, its on fairly late. Yet if it feels like its on much earlier I'm guessing it actually has good pull before being on boost?
its hard to explain it does not feels as it looks or sounds buy the dyno or the full boost by 4800 i need to do a vid on the car
If the efficiency of the engine drops off your VE numbers will tend to flatten out and sometimes run backwards.
That torque curve says it all. Add some more boost if you have a decent controller with rpm correction at the point where the torque curve falls over (150km/h). Power will keep climbing and torque curve will stay flatter.
Edited by Shane_954
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
