Well i have heard many of the GTRs around adelaide have been in the past attempted to be stolen or stolen. The guy responsible was eventually put away, was caught red handed in GTR. How true this is, I don't know.
Where i used to park my car (last year), near the river at adelaide uni, the cops said at least 3 cars were taken from there every week. A GTR went missing from there too early last yr. After my number plates dissapeared from there, i decided not to park my car there anymore. The GTR recovered just had a small nick on the passenger side door where what appeared to be a screw driver or something had been instered to open the door. A computer of some sort was then hooked up to the car comp to override any immobs/alarms...The ignition barrel was stuffed.
I know I would be hysterical if this happened to me, despite insurance. I too despise car theives!
If you leave your GT-R in public view what do you expect?.. ofcourse some jealous scum back is going to come along one day and try to steal it.
the best insurance is to buy some $2000 car to run around in and leave in public :( lock your GT-R away when not neeed.
Even though I only have an RS-X (which I guess is same thing as a GT-R :) ) I would never leave the thing parked on the street for long.
the best insurance is to buy some $2000 car to run around in and leave in public :) lock your GT-R away when not neeed.
exactly what i do!
i dont have a gtr either, but ive put too much time and effort into my car than to have some f**kwit come and mess it up for me.
i aint got a GTR but if i caught anyone fooling around in my 33 id call the cops after done punishing them.
PS, if they know what their doing, chances are their on this forum, tracking you down in the GTRz0r as we speak =P
sounds too organised to me
do you think some person /persons are looking around these forums to find locations of gtr's ?
probably..
apparently the police lurk these forums as well so i wouldnt be surprised that ppl other then skyline enthusiasts go on here
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
