  • 3 weeks later...
Bit of a small thing but need the number for the standard speaker covers for the rear speakers in my series 2 r34 GTT (unsure if different to series 1 have been told they are)
28174-5P600 RH
28175-5p600 LH
those should be close, however being a trim part i would prefer to have a vin number
Does anybody knows the part numbers from:
R34 GTR Front Bumper V-spec
And the optional lip
Also the R34 GTR Front bonnet V-spec
And Front fenders from R34 GTR.
Thank you all!
Akis.
Front bar F2022-AA4MD
Front lip 96015-AA440
Bonnet F5100-AA4MM
Fender RH 63112-AA430
Fender LH 63113-AA430
Need part number for 1990 RB26 non n1 waterpump..
Searched but i have found like 3 - 4 different part numbers!
I think 21010-58S25- may be correct can someone confirm for me?
21010-58S25 is a good number for R32 RB26DETT engine
urgently need the part number for the seal between the injector rail and injector intake.
much appreciated if someone could help me out.
cheers.
please confirm if highlighted part is correct?? (poor description)
Does anyone have the part number for R34 GTR front fenders? Looking at doing a GTR front end conversion on my 4 door 34. Thanks.
please refer previous post about GT-R vspec fenders, bonnet and front bar. guard part NO. are the same
hi i'm after the headlight switch on the side of the gauge cluster (have the one headlight problem, pulled it apart but it's totally screwed) :)
bnr32
1992
model: KBNR32RXFS AA
chassis: BNR32-221349
thanks
did some searching came up with this:
25160-01U00- Switch Assy - Lighting no
can anyone confirm?
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
