i just wanted to share this pic that i've taken with my phone...hilarious, the money that was spent on this car i believe the owner could've just went out and baught a real turbo car.
a chick owns that car that used to go to my tafe last year, and thats her picture thats airbrushed. You shouldn't hate, appreciate :) :laughing-smiley-014:
https://www.sau.com.au/forums/topic/172911-rice-burner/#findComment-3181041
hahahaha no apreciation..... just lots of WTF???
https://www.sau.com.au/forums/topic/172911-rice-burner/#findComment-3181157
a chick owns that car that used to go to my tafe last year, and thats her picture thats airbrushed. You shouldn't hate, appreciate ;) :laughing-smiley-014:
i dont believe that.....prove it my friend, prove that it is her.....picsorban :)
https://www.sau.com.au/forums/topic/172911-rice-burner/#findComment-3181268
the FAKE fmic looked so f###ed that who ever walked past that car at that time laughed at it rather then appreciating it, those pipings look like regular pipings that you buy from Bunnings for 99cents a metre on special.
1/ Bunnings don't have specials :P
2/ What do you think ic piping made from? Mine are just regular, mid steel mandrel bends.
https://www.sau.com.au/forums/topic/172911-rice-burner/#findComment-3182349
You have missed th epoint that some ppl like to ice up (or do up) a car that they have or just want to be differnet.
Maybe they don't wanna spend money on performance but want a cheap stand out car.
Remember, some ppl have no clues. haha
I know of people who have turbo'd non turbo cars, only to gain 190kw at the front wheels - pointless IMO, but they love it.
Truth be known, the 50k spent on it could buy you a very good R33 GTR example.
Horses for courses I guess. The orld would be boring if every man and his dog poured $ into Skylines - even though these are my preferred fun car.
https://www.sau.com.au/forums/topic/172911-rice-burner/#findComment-3182534
this thing does enter autosalon comps....was in the semi final I was at end of last year. YES it is the chick that owns it on the bonnet, AND it won best airbrushed car from memory...or at least runner up.
I thought it was deffinatly in the "why whould you" catigory.....but each to there own I guess.....
thats actually like a big airfilter made to look like an intercooler. It is hooked up, but works on the same principal as a huge pod filter. Ive seen heaps on Pulsars getting round. They get em at autobarn i think?
still.........why would you????
https://www.sau.com.au/forums/topic/172911-rice-burner/#findComment-3182606
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
