Why is there crap being posted in NSW this isn't club related and should be in the photography section.
Crap??? WTF???
Gee thanks Corine...
Maybe if you worded it, "i think its (enter thoughts here) however, it should be posted in the computer section"
Cool nice work man :blink: i'm useless with anything photoshopped etc
Corinne you get emails whenever anyone posts in the NSW section??? Bit over the top.
I've seen a lot of posts in this section unrelated to anything club, such as video's on youtube linked etc etc, don't see you abusing people in there...
it's not a photo....
this is the NSW section.. not the NSW club section.
NSAIIN, looks cool.. intercooler pipping is a little straight at some points. but looks cool
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
