Plenty of pics of UAE drag cars (including skylines) here:
http://www.motorplex.ae/PhotoGallery.aspx?...=48&GPage=1
FSW, I have seen the Speed D car site a few times and have followed its progression. Some great results there. I do find it strange that they have reverse-flow mounted the twin entry drag cooler.
Yer i can get some details for you as Mario tunes my GTR for me. I seen it run its 8.2 sec pass and the car is very impressive. Mind you it is even down to carbon fibre door skins. But you should hear it run......sweeeet.
Mario's father told me the engine was good for 900HP at the wheels
But to be truthful you should see his sand run patrol...that thing is just bloody plain old scarey
im disappointed, no one has introduced them to 9sec all day vl turbos....
ok guys heres a brakedown of my car
rb26 stck strock stock crank, stock block 86mm custom srz(cp pistons),alloy GRP rods,custom ATI 2sd with 4wd adaptor by MICK AUSI TCE converter which is crap changing now to neil chance,head= 2mm over size titanium valves, double titanium valve spring by ?????? ,titanium retainers. custom custom :thumbsup: 12.8mm and 12.6 mm @ 311 ,299 jun cams ,SZR dry sum setup, Custom SZR intake 80mm T/B ,SCUBA STEVE water cooler , SCUBA STEVE exhast manifold , 88mm borgwarna AIRWERKS turbo 47psi ,NITROS EXPRESS 300hp kit only for spool up , 11.5, 26 , 16 et street tires ,
HP 930 whith out gas 1234 with gas on dyno dynamics dyno
best time= 8.1 testing 8.2 race day MPH 174-178 with out gas and 1.7 60ft
having trobles getting off the line and when i use gas the car gets way crossed up and 2 dangerous so yeah its good for mid 7s
Fuel= C16
next mods=single peice carbon front end, bigg tires 15/10.5/28 all round ,new converter ,and big weight reduction as the car is way 2 heavy 1320kg dry. ohhh yeah and
rb26 stck strock stock crank, stock block 86mm custom srz(cp pistons),alloy GRP rods,custom ATI 2sd with 4wd adaptor by MICK AUSI TCE converter which is crap changing now to neil chance,head= 2mm over size titanium valves, double titanium valve spring by ?????? ,titanium retainers. custom custom ;) 12.8mm and 12.6 mm @ 311 ,299 jun cams ,SZR dry sum setup, Custom SZR intake 80mm T/B ,SCUBA STEVE water cooler , SCUBA STEVE exhast manifold , 88mm borgwarna AIRWERKS turbo 47psi ,NITROS EXPRESS 300hp kit only for spool up , 11.5, 26 , 16 et street tires , HP 930 whith out gas 1234 with gas on dyno dynamics dyno
Fuel= C16
Woowww.... Thats insane. Well, there's a new record for a DOT tyred Skyline as far as I know. And plenty more in it by the looks, amazing effort man!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
