  • Replies 121
i do it for cost and so the wheels sit better in the guards
ive got 205's on a 8.5" on the front and 225's on a 9.5" for the rear.
looks depend on the tyre also, previously i had a set of dunlops that were 235 on the rear and they looked like they were stretching more than my current 225's
I've also had the same thing with dunlop and bridgestone 235/45/17's being quite different on my 9in rim. The Bridgys look stretched and the dunlop sat square.
I like the look of it and the less sidewall flex.
from a grip standpoint, your getting less tread on the road though
Not exactly true. The tyre width does not determine the size of the contact patch. All else being equal, a 225 tyre will have the same surface area touching the ground as a 245 width tyre.
Huh? Am I missing something? skinny tyre=less surface contact, fat tyre=more surface contact?
I always had 235's on 10.5" rims. Same reason as said before, any bigger would rub.
That's pretty good fitment mate.
Any chance you can explain?
With your 14x10 Longchamps, you've dumped it till sparks off man holes and with as much camber as you can dial in the tyre still hits the guard, you need to stretch. This is where the fad all started ladies and gentlemen.
And here it is, 195/60/14 on 10inch.
I had another read of the post, and in the context it was posted I'm probably wrong. With an ultra-stretched sidewall, that doesn't flex as much as one with a "proper" fitment, the contact patch will be smaller.
Which is probably why didn't reply to his post the first time......
But if you run two tyres of different sizes on rims that they're "suited" for (like say a 215 width tyre vs a 245 width tyre on a 7.5" wide rim) then the difference in contact patch between them is minimal.
right australian manufacturers know everything...
ahhhh this is why in germany cars such as porsche and mercedes come with stretched tyres from the factory....
that's right, it's PORSCHE that know nothing., ah keyboard warriors were right the whole time, should've known...
"Imagine driving on to a glass road and looking up underneath your tyres. This is the example contact patch (in red) for the situation I explained above. The narrower tyre has a longer, thinner contact patch. The fatter tyre has a shorter, wider contact patch, but the area is the same on both."
Because you now have more space the weight is less per cm so the contact patch decreases. Of course all sorts of factors change this, eg tyre pressure, how much its stretched etc.
Stolen from http://www.chris-longhurst.com/carbibles/tyre_bible_pg2.html
They might stretch them but its not ridiculous stretch eg a 195 on a 9.5" rim.
Edited by Rolls
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
