After swapping my rims I am thinking of restoring the HID myself too. The balast plug was cut pretty close to the plug itself so i am wondering if I should find certain type of wire/cable to lengthening the wire? e.g. I heard of people saying 8 gauge, 12 gauge, what are those sizes? What wire is save enough for HID wiring? I don't want to accidentally getting a wire too thin that just overheats and melted or catch fire.
  • Replies 140
I didn't thought of it. Must be loosing some more dead brain cells at that time...
I was thinking to access the lights by removing the front rims and open the wheel well plastic shroud lining. Rather than dropping the bumper. I think that's easier?
Anyhow, what wires size should I use for 12V DC (the one going into the balast, not the ignitor after the balast) if I want to extend the wiring?
PS: have you checked your email, Chris?
Hei, I have the same problem, the wire was cut to short to the plug. It's easy, use a small flat head screw driver, dig out the white plastic piece. Then using 2 small flat head screw driver, One to push up the locking mechanism, one to push out the female pins. As for me, I just cut off the wire where they joint up the halogen bulb and solder on the clean out female pins. Wha la, you have the original plug on the wire that looks untouch. As for the purple rubber thingy, just push back to fill up the hole in the plug.
Thanks CHRIST :thumbsup: for the info on the blown fuse, I accidentally reverse polarity on one of my lamp. Blown one of the 15 amp fuse, which can be found behind the battery.
  • 5 months later...
Thanks CHRIST :) for the info on the blown fuse, I accidentally reverse polarity on one of my lamp. Blown one of the 15 amp fuse, which can be found behind the battery.
Hi mate.
If you need help. I am more than happy to give my hand. have done a lot with my head light, include put back Xenon. upgrade to 06, quad HID etc......
drop me a message if you need me
Frank
Looks like I have missed Chris for any time soon for lights conversion. Tried Just Jap - apparently they don't do it... Doesn't make sense as they get cars complied....
Anyone know any other places around Sydney? Local electrician, that no one has been to, is not an option - ones I tried didn't have a clue that you had to either take off the bumper or access from underneath. That is worrying to me.
Edited by russky
you haven't missed me
I'm still here, but I cannot get into the workshop I use here. the neighbor has a LOT of crap parked in front of the main entry.
that said - yes I can do it BUT I will only do it IF you have the OEM items and not a retro fit kit.
as for the drivers lock - as I said earlier in the week - I CANNOT turn around a part ex japan that quick. I ordered 3 left side actuators and not a right side one.
next time u down here, chris, what's a good bluetooth setup and rear cam? but i think i've run out of input channel though....
unless there's a way that the rear cam 'takes over' the screen whenever it's in reverse (powered by reverse light +12v)
The Kit I have is the Bosch from the group buy.
As I said, I am in no rush and more than happy to wait for an actuator and the next time that you will come down here (presumably gone by the time actuator would arrive and assuming both instances will occur within this year).
  • 4 years later...
Hey everyone, I'm new here.
I have a friend of mine who owns a Nissan Skyline 350 GT and has just purchased a new set of headlights.
Unfortunately, he didn't pay enough attention while buying them and purchased a kit that requires the stock HID bulbs in order to work.
Now he has the headlights fitted in the car with no low beam bulbs at all - bad choice, I know. I'm trying to retrieve the stock HID "socket" that was originally taken off before the car was shipped to Australia.. but it seems kind of hard to find it online. Have you got any idea on where I can buy one?
Thanks a lot.
Btw here's a pic of what I need: that sort of socket with metal covered wires that goes from the HID ballast (which I already have taken off the stock headlights) to the D2S bulbs (which I also have, xenon, 6000K).
ps I know the thread is really old but it's the right discussion so I'm posting here. :D
Edited by Obyboby
  • 5 years later...
Hi guys,
I'm pretty shocking mechanically.
I purchased the following headlights for my 2003 350gt v35, the item description says I may need an adaptor kit. I feel the main light bulb is xenon but the strip light isn't? No clue. Just wandering if someone is kind enough to advise what I need to do to get these in?! Im in Melbourne and would pay someone for their time for an install.. but I would like to know what else I may need to purchase..
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F322416869577
Any guidance much appreciated.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
