its not the higher octane that leans the af's out but more so the 5% ethanol in v power racing. u have to run your car slightly richer when using ethanol but the bonus is u can run alot more timing hence make more power. this has been proven using 2 different fuels both 98ron however one was e10 and the other had no ethonol. the e10 ended up making 30kw more power after a re-tune on the same boost. so if u have the stock computer then definitely run V power racing it'll only make things better. however if u have had the af's changed i'd recomend getting them checked with the V power racing fuel to make sure they're safe.
  • Replies 42
yeah I no longer run stock computer. have a pfc tuned to around 12:1 afr so guess I should just stick to 98 for now.
If I do get the car tuned on 100 octane V Power Racing later on, would it hurt to run 98 octane (v power, ultimate) occasionaly in case V Power Racing is not available?
Edited by BaysideBlue
getting car tuned on 100 n then go use 98 isnt advised.
WHat about Boost 98, E10 98RON?
Has ethanol content but 98RON. Does the car still need to be retuned in order to run it safely?
skylines are ment for 100 octane as that is standard octane in japan :thumbsup: so there already tuned for that
wait, is there a difference between standard 100 octane in japan and V power racing (100RON)?
I have been told our standard 98RON fuel is equivalent to 93 octane fuel in the U.S?
100 octane fuel is not 'standard fuel in japan'. Yes 100 octane (and in some places higher) is available but 99% of all japanese cars, including skylines etc are happy to run on 95 octane when standard. obviously when modified a better fuel is a smart choice.
bayside, the reason people would tell you that is the US use a different method of measuring the octane rating of their fuel.
Here is a link for a Motec test on V-Power Racing - there is a pdf that has detailed report on what they did and what figures the acheived - it even outperformed avgas when the engine is tuned correctly!
so if you tune your car right you can expect some good results from V-Power racing it seems
http://www.motec.com.au/fueltest/
Thanks. Great article!
Worth a retune to 100 octane it seems, a relative cheap way to get more power with the benefit of higher anti knock safety margin!
Whats the deal with North America having 100 octane fuel (105RON equivalent) available in selected fuel stations while the best we have in Australia is "only" V power 100RON?
I don't know why they get higher rated fuel, but I guess they have a pretty good handle on controling the crude oil market...
I can get 102 on pump here in adelaide (4$ a letre tho)my 12.1 rally car needs that and avgas(110+) on pump here too(2,20$ a litre)but u need racing licence for that.I tried 102 in my skyline but nknew it would only be good for cleaning it out.nissan recomend 100 or at worse 98+
Edited by cosworth1971
Cheers BaysideBlue
Yeah it is basically free horespower without makeing any mods to your car, well no mods aside from tuning the car to suit - if you can get a few extra horsies just by pumping them into your tank rather than emptying your bank account and bolting stuff to your engine (and then having endless troubles when the mods you put on don't work and have to make more mods to get the original mod going right - c'mon someone here is nodding having been down that road like myself) than that is a good thing!
I filled up a tank of VPR and so far i do notice the difference - just waiting to see how many K's i get on the one tank - so far looking good
Edited by pinni74
I noticed jack all difference... Pretty stock r34 .. maybe slight power increase down low .. Noticed id be at redline faster but cant feel it much .. Cost me 1.51 a litre and did last longer but to get it is hard and for the cost its a rip..
If you want a power boost hit up caltex vortex :(
If you want a power boost hit up caltex vortex :P
Ah yes but bear in mind you need to advance the timing to get maximum benefit from VPR it will improve your performance - you car is tuned to run 95-98 not the 100RON - give another tank a bash and get your timing adjusted - if you get it all right you will see better performance on V-Power Racing. :(
Its been said bu using the ethonal based fuel will cause yor car to lean out, if modified and not tuned for the ethanol..
Mines tuned on BOOST98, the fuel is cheap and i got great results with it..I think the ethonal fuel was the basis on the surprising power output my car made (40rwkw more then I and everyone else expected and imagined)..
The benefit to using ethonal is the timing they can add into the car which = power.
mid range power yes but less timing u can go within reason is best for top end.depends what u want?
and no u wont feel massive power gains with 100 octane but maybe 1/3 second a lap if your timed
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
