hi,
just wondering what you peeps out there do to get rid of any annoying interior squeaks and noises?
I have a couple, and firstly, find them hard to pin point and second have no idea how to get rid of them.
I have an R34 and the area around the top guage cluster has a bit of a creak to it, not sure where exactly.
just wondering if anyone has any processes they use to elimante unwanted noises, or if anyone knows of any common causes for the squeaks, etc...
cheers
yeah its a bitch aye. Try taking off the interiour panel and putting a really thin sheet of foam/sound deadening under it. Or maybe a drop of silicone over the metal clips so they dont vibrate
I always try and push on everything at different points while it's rattling.. see if I can narrow it down to the bit of plastic, panel, etc that is moving around. Often it's just a screw undone..
After I've found it I'll shove a bit of folded paper in there, or obviously replace the screw.. generally I'm pretty successful at getting rid of them on most of the cars I've had.
yeh bro ive got an r34 n somewhere in the back seats where the plastic overhead things are theres a major squeak noise everytime i go over bumps..n it also comes n goes..
some days its nice n quiet and some days u just wanna rip the interior out
whenever I turn up the stereo my splits make an annoying vibration noise in the rear parcel shelf.
Not sure if it's the plastic brackets or the speakers, but it's very annoying, anybody got any tips?
^ so Porshe's come with felt tape from the factory?
felt tape.... silicone stuff... foam deadening.... paper :) - some good things in here :blush:
i've got one "creak" on my drivers door, in the cloth/fabric section (under the window) how would i get behind there? take the whole door trim off? i've NEVER dismantled any trim before, is it fairly easy to do?
it is. just remember to go slow the first time, be careful and make sure you are applying force in the right spots. once you've done it once it becomes a lot easier. try to be even in you pulling too. if you are bending things that arent meant to bend, you are gonna do damage.
EDIT: re reading that bit of advice, i rekon that it can be applied in a totally different "first time" situation too :D:(
That's pretty true. I don't remember or wouldn't have noticed on our old 320i, 528i. But the 530i i believe is squeak free, the 335i has a little one that's popped up (and considering it's less than half a year old, that's not too good) but the suspension is much harder. The 318i has a few noises.
i think the stiffness of the suspension plays a huge part. The stock R34 suspension i find is actually quite stiff, or the shocks are crap, or something, i dunno.
I have an annoying creak in the passenger side inner rear trim, the one that runs along the top of the rear window and down...
Ive tried squeezing silicon filler in there, and still no dice.. If I knew how to remove the bloody thing I could get in there and take care of it properly! Anyone happen to know how these panels come off?
my door tirm has the sounds..
if i press down or put my arm on the door trim while im driving it crys out like a pig...
same as passenger side door trim..
and also if i press down the back seats, it makes metal scripping sounds... i think its because of bushes... anyway...
i have to dissemble those trims and put somethings between connections.... i hate that noise....
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
