hey guys, im gointg to attempt to make a rollcage for my drift pig!
i got no idea where to start. ive been sussing out designs etc..
i plan on stripping the interior and making it a weld on not a bolt on...
anyone know what thickness piping i should use... also miled or stainless etc?
fat chance but anyone got a write up?
cheers
https://www.sau.com.au/forums/topic/174160-roll-cage/
Also have a look in the gallery on that site i linked above, has some different designed cages to give you a few ideas.
Cams approved cage bent up for a series 6 RX7 cost about $900 for material and all bends and cuts, then you need to weld it all in ... it might be cheaper for other cars due to the rx7 being a complicated design. that was from a places in Mc Graths Hill NSW
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3198435
Craved i've discussed with Eddie (p.c.e) about rollcages in the last week and will probably be getting him to do a basic 4 or 6 point cams design sometime in the next <3mths. Actually he's doing 1 for a DR30 and 180SX right now at the shop.
Think he said the seamless costs him $26/m where as he can get a full length of exhaust tube for less then that.
Edited by benm
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3198724
i have payed $26 a meter for 2" 304 stainless pipe for exhausts.. so that seems pretty cheap. its the mandrel bending thats the really hard part, without spending alot of cash on a hydrolic/electric bender.
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3198738
if u wanna make it real awesome weld some bars that join up all the strut towere through front firewall etc. Maybe even rip out dash and weld a new support bar through the dash replacing the stock one. Goodluck and post some pics
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3198829
No point doing it if it isn't going to be done properly, likely to just inflict more harm on yourself.
I dont think you could stress that pioint enough if you tried :)
A poorly made/designed cage is MORE dangerous than not having one at all.
IMO - Your better off paying someone who knows what they are doing.
For ~ $700-800 you can have a 4-point fitted in mild steel to a skyline. Which, for your own personal safety, is absolutely nothing.
You might save a few hundred with DIY, but if its not correct, your more likely to die or permanently maim yourself in the event of an accident than if you had no cage at all.
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3205363
ben the one you posted won't pass, it needs at least 1 diagonal, normally between the b pillars although I've also seen a-b and b-c on opposite diagonals. You don't need the horizontal bar between the b pillars for the rules but it is a good addition
we are doing this atm, the main problem is mandrel bending the main hoop (b pillar) you can't use a normal pipe bender it will crush it too much losing the strength.
The other main trick for CAMS is you are only allowed to have 1 bend on the front legs so you need to go through the dash, you can't bend around it.
And if you don't think strength at the A pillar/roof is important think again
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3205572
That wasn't the 'exact' design im going to get but it was the closest I could find on google in 3mins at the time.
My exhaust mechanic does the cages, he has a normal pipe bender but for those b-pillar bends he uses a mechanics machine up the road from him, the rest he can do on his pipe bender. Not sure on costs yet because I haven't even got my panel damage repaired yet (even though I have half of it in primer :P)
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3205623
;) Having my non abs s.wheel go through my skull, as well as worrying bout a tube from a snapped home weld isnt on the cards.
*thinks* wheres that home made helmet thread :P
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3215752
Heress a link that will no doubt assist in this roll cage
http://www.metalgeek.com/cgi-system/php5.c...tatic/cope.pcgi
it will determine the cut required to closely join tubing in order to have a neat joint and allow good welding.
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3220554
  • 4 weeks later...
hey guys! my old man, at seven hills has all the tubing u will require to bend/build ur cage.
call him on: Rod Andrews - 9838 0032
and say that i put you onto him for some chrome moly or mild steel for a cage!
he has a bender there too, and we have done 1000's of cages since the shop opened in 1989.
so talk to him if you have any queries, make templets out of cardboard to suit ur roof profile and "b" pillar for your main hoop! and start workign form there. and if you want it cams or andra approved or any other racing approval, check with the governing body before attempting to BODGY one up!
Garth
https://www.sau.com.au/forums/topic/174160-roll-cage/#findComment-3263214
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
