  • Replies 951
I have sent you all pm's let me know how many nights you are staying and I will book the cabins for us :)
There will only be 6 to a cabin Max! and two people have to sleep on the queen size bed and 4 on the single bunk beds...so let me know if you want to be paired up or percific people in your cabin???i.e not the snorers lol!!
Can we please get a list of people that are coming down to spectate and be our NSW support crew!!!
We need to sort out accomodation asap and I need to starting getting numbers so can see how many cabins we need :)
Please confirm if you wish to come down to DECA for an excellent weekend away...
Spectator list:
Henry (Vic's Cousin)
DRD-OOF
Jason (Andos mate)
Kelly(you in if you like it or not!)
Nigel??
Tinks??
Jet R32??
Jess - Morgs might be coming also as a spectator, but he lives in VIC already so he wont need accomo
Coolies :D
How many days are you staying down at DECA and do you want a bed in one of the cabins?
Or you going to snob us and go to a hotel
I'm happy to have someone ride down with me, but I'm headed down Thursday as I'm headed to Winton of Friday for a track day. Several of us will be getting a cabin starting Thursday night.
For a seriously long drive its actually a pretty good time.
Like has been mentioned we're going down way early but im taking the XR6 and trailer, if anyone has spare stuff like wheels etc they want carted down let myself or corinne know and we can organise to take them.
Jess I was talking to andrew about tires last week. Im going to be using a new set of R888's at winton and Corinne will also have a new set on too.
Brad
Edited by Risking
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
