  • Replies 951
Spoke to Mitch (Mr Moo), Kasey and I are taking his accomidation for Deca. Sorry Bishes, Gotta be quick!!
Ohhh, spooning in da cabin...can't wait baby - you & me!!!!
PS - looks like it'll be a rock off for the double bed!!!
:wave:
:wave:
Spoonin FTW Jen baby!!!
Nah, no rock off, trust me its ours.
Im sorta confused reading the above, but it sounds like 2 of you are pulling out.
Steve-O - can you find out definately and confirm please ASAP (let Scotsman know if you can).
As we have a long list of angry Victorians who missed out on spots for this DECA, if you guys are pulling out, we need to know so we can offer the spots to them instead.
Cheers
Bec
wtf why is everyone pulling out?
did my fart smell?
yes, yes it did, its just that the people that put up with you the first time have built up a tolerance :/
dw mate, if worst comes to worst the original DECA biatches will make it!!
yes, yes it did, its just that the people that put up with you the first time have built up a tolerance ;)
I couldn't agree more Sam, cannot wait to do it all again....
Yep alive.... no car... but alive... grrrrrrrr
But never fear, Il still be there competing... although does it matter if I change cars at the last moment????
Seriously thinking of taking up the offer of a borrowed car that was made....
No thats fine - You can bring what ever car you like, as long as it's road worthyish..
A31Deviat - Get some temporary / unregistered vehicle permit. Say you need to drive it to Shep, VIC to show a potential buyer the car.
Yes people i'm going to less and less time to read this thread, so PM me or SMS me if you are pulling out. THIS IS IMPORTANT!!
oki .. well my accom will go to the nsw people... shaun, steve and aza.... you'll have to share.
but seriously, I'll speak with you guys about it.. coz I don't want to play favourites... i love you all!
Well i am out as well..... so there are 2 beds up for grabs....... will PM VIC dude now to let know space available.... ;)
I will be back for Sutton Rd bigger better slower!!! :D
:rofl: .... wrx not good enough for ya ??? :(
No not that at all, just decided that i will go mental being down there and not being able to drive.... so decided all or nothing... ended up with NOTHING!!!
Appreciate the offer x 11ty billion ;)
Appreciate the offer x 11ty billion :rofl:
No worries... you could of driven the wrx in the events you know ... you break it.... all good... I hate that damn car... :(
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
