Trying to take my diff out and no matter what i do the bolts wont come undone, i've tried putting a ring spanner on the end of the spanner and thats not working and i've also tried hitting the spanner with a hammer but that just resulted in a broken spanner!
any ideas would be much appreciated!
Cheers!
https://www.sau.com.au/forums/topic/174786-tailshaft-bolts/
Get yourself some sort of penetrant like CRC etc and douse the bolts and give it time to penetrate the threads and loosen them up a bit.
Now use a socket and breaker bar (if you can get one) and put a long piece of pipe on the end of it to get some extra leverage on them.
Or if you had access to a rattle gun....
https://www.sau.com.au/forums/topic/174786-tailshaft-bolts/#findComment-3205729
if its rounded then yes you've made life hard for yourself. these bolts are a very high tenstile bolt and if your using a poor quality spanner you will round them, or break your knuckels... or both lol.
the trick is to use a LONG 14mm spanner, of good quality, or a short quality one with another one on the end to add leverage. get a mate to shove a long flat head screw driver through the tailshaft uni joint and pull that opposite to you.
since its rounded... you're now going to have to either cut it off with a grinder using a very thin cutting disk, or weld on a bit of steel to the nut, and then put a breaker bar over the steel to undo it.
https://www.sau.com.au/forums/topic/174786-tailshaft-bolts/#findComment-3205856
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
