So basically ive got $35,000 to spend including the buying of the car.
Selling my 180sx right now and im upgrading to a R32 GTR.
I was thinking $20,000 for a basic nice condition GTR so that would leave me with about $15,000 to play with.
My question is what mods should i get and what would be the power ill be looking at most probibly a good question for people that have already gone down a similar path what quater miles do you run aswell.
Oh and my names Rory nice to meet you all :P
https://www.sau.com.au/forums/topic/174790-r32-gtr-plans/
do everything at once to save some time and money on re-tunes.
I bought a stockish car and went down a similar path to you. First off i fixed any mechanical issues with the car like brakes, belts, fluids, 100k service. Make sure the engine is healthy to save you pulling it apart during the build up.
Then i collected...
turbos GT-SS
injectors (sard)
cam gears (arospeed)
fuel pump (nismo)
afms (nismo)
dumps (tomei)
Power FC
02 sensors (nissan)
metal cat :P
Coil packs (splitfires)
....and fitted everything apart from the turbos/dumps and cam gears myself to again save money. I paid a little extra and went for some nismo components for ease of install.
im still hoping to run a mid-high 11 with a bit over 400rwhp.
The car already came with a twin plate, exhaust, bilstein shocks, eibach springs, ARC cooler and Greddy hard pipe kit.
I know its an old engine but it makes power early which enables me to keep revs below 7500rpm, hopefully prolonging its life a little longer.
I only boost once oil is over 70 degrees celcius also.
Welcome aboard Rory!
Edited by SLIPPERY
https://www.sau.com.au/forums/topic/174790-r32-gtr-plans/#findComment-3205783
Ill do prices aswell..
turbos GT-SS $2800
injectors (sard) $580
cam gears (arospeed) $180
fuel pump (nismo) $550
afms (nismo) $400
dumps (tomei) $600
Power FC $950
02 sensors (nissan) $420
metal cat smile.gif $250
Coils (splitfires) $470
Labour for turbos and tune: $2600
Total.... $9800
https://www.sau.com.au/forums/topic/174790-r32-gtr-plans/#findComment-3205786
Basically i want to get as much "SAFE" power possible out of the rb26 without doing any internals. Will probibly keep it like that for a while and just save alot to be able to build the engine all at once internally.
Was thinking of somewere along the lines of getting this for now:
2 new turbos "What size is appropriate for no internal work and max safe tune power"
cam
injectors
fuelpump
powerfc
boost controller
exhaust
pods
Would i need an oil cooler and stuff or isnt that needed untill your really pushing for more power and going passed that safe point.
Also what is the safe point in a rb26 owning a 180sx i know the sr20 safe point can go upto 280rwhp and then youll have to start looking at building a stronger engine.
https://www.sau.com.au/forums/topic/174790-r32-gtr-plans/#findComment-3205806
400rwhp is a figure a lot of original engines are still able to push out fairly reliably
The turbo choice for a non built motor would be GT-SS's, garrett 2860-7s or -5s, & 2530s.
A stock motor wont be able to completely push the -5s or 2530s though but would serve well in the mean time if you needed to rebuild the engine later
An oil cooler is a good idea for a rb that sees trackwork.
https://www.sau.com.au/forums/topic/174790-r32-gtr-plans/#findComment-3205818
Look for a GTR with a built motor, you'll find one floating around the 35k range easily enough.
A 20k GTR is going to be average at best
Better doing it that way then buying a 32, and then lean on the motor and little and it goes pop.
Then all of a sudden your 15k is totally blown away :P
https://www.sau.com.au/forums/topic/174790-r32-gtr-plans/#findComment-3205852
You can get a nicely modified gtr these days in the high 20's, then just keep the extra $5k for changeover, insurance and anything minor that needs doing.
Sure buying a stockish gtr and pumping $15k into it might be alot of fun but its definitely the most expensive way of going about it.
https://www.sau.com.au/forums/topic/174790-r32-gtr-plans/#findComment-3205913
Then all of a sudden your 15k is totally blown away ;)
:P
https://www.sau.com.au/forums/topic/174790-r32-gtr-plans/#findComment-3205983
im even with the other guys...buy one with a good built motor. I looked for a while in WA when i was buying but couldnt find anything.
But hey, if you want to build one yourself and be sure of the condition then theres a guideline there
Edited by SLIPPERY
https://www.sau.com.au/forums/topic/174790-r32-gtr-plans/#findComment-3206279
