  • Replies 134
to get the mines r34GTR either-
-win amateum GT all stars
or
Endurance trial mountain
both are random prizes, and it is alot easier to get in the GT all stars championship.
simply win most of the races, and on the last race, if uve got at least an 11 point lead you can save and quit. then u get your money and your random car, and if its not one u want, simply load again, and ull be just before the last race. keep doin it until you get the car u want (and the colour u want)
this works for championship races only
u cheapskate funkymonkey, using one of those memocards cheat things......
lol i actually clocked GT3 to start with, then i got bored n put it away for a year or so... then about a month before our first autosalon (a year ago) I got it out and gave it another go, while doing so I found it too easy and repetetive... so I went on the net, got on ebay and bought a memory car editor. Hooked my memory card up to the PC and did some hex editing of the save games.
Basically I unlocked the Mines GTR, then I saved it, went into the save game, and modified the stats of the car, so it has the weight of an MX5 or something, stage 3 weight reduction, Escudo Engine, Supra Gearbox, V12 F1 turbos or something, etc etc. I haven't touched the boost multiplier yet (so its doing what power those parts can do when they work together). So by using stock parts from different cars I basically made the fastest car I could. Then i took it out on the tracks and had some fun.
If you guys want a copy of the car I can upload it for you, but you'll need a memory card link for the PC to upload it to your card.
only problem with the car is that it now has too much power. I'm gonna have to make the car heavier to get the car a bit more traction. Usually by the time I'm in 3rd gear (out of 6) I've burnt up all my tyres. And yes, its expensive to maintain as you have to replace tyres every time it goes out on the track.
ok, my drift cars are:
-S13 silvia k's (2000cc)
-S13 200SX Type X
-S14 200SX
-S15 Silvia
-FC3S RX7
-FD3S RX7
-Tom's X540 Chaser
-R32 Gts-t
-Sprinter Shigeno Version
-BMW 318i
similar setup on all the cars makes the all equally easy to drift. i found it easy to set up the suspension close to that of a real car, ie camber: (F) 3.5 ® 2, spring rate (F) 10 ® 8 etc.
if you have any questions PM me.
Joel.
  • 3 weeks later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
