hey all .
im new around here just joined up as my current car is for sale and i am looking for a r32 gts-t.
but i have a few questons regarding them:
do all series r32's come with the projector headlights? or just the late model ones?
what is the differences between s1 and s2?
anything i should look out for when looking at a car? i.e rust in common places etc?
also if there is anything you want me to kno about when looking at them plz tell me.
cheers
jono
https://www.sau.com.au/forums/topic/176358-r32-gtsts/
projector headlights came in series 2 r32's
Difference between series 1 and 2 include;
- s2 heavier by a bit due to reinforcement bars in doors.
- Different steering wheel (tried fitting s1 wheel onto my s2 r32 yesterday, completely different setup yet they look the same)
- s2 plastic interior is the rough grainy look, where s1 has smooth plastic around the headunit etc
- s2 has grey faces on the dash, where s1 has blue
- s2 has a different ac compressor
- s2 has different interior cloth on the seats
- s2 most come with electronic front spoiler (although i think its an option)
There is a lot of small differences between the two series' but they all make a difference :thumbsup:
https://www.sau.com.au/forums/topic/176358-r32-gtsts/#findComment-3226726
